Dyemor Posted September 3, 2014 Share Posted September 3, 2014 Hey guys, I'm having trouble finding a consensus on vertical firing arcs on fixed hull weapons on fliers in 7th. This would affect the shooting from the Stormfang quite a bit with things like the TL Las Cannons (fixed) and the Multi-Melta's which only pivot side to side, not up and down. Not to mention the large gun on the front of the Storm Fang would only have an effective range of about 12-24" if it only has a 22.5 degree down arc. Is there a faq or something somewhere which says that fliers don't have the 45 degree vertical pivot or what do other people play? Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/ Share on other sites More sharing options...
Nadir Posted September 3, 2014 Share Posted September 3, 2014 Main book p.74, 3paragraph. Weapons that are hull mounted and can not move on the model, can aim vertically and horizontally at 45*. Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/#findComment-3798679 Share on other sites More sharing options...
eyeslikethunder Posted September 3, 2014 Share Posted September 3, 2014 The stormwolf does naturally sit on the stand at several angles due resting against the angled chair which resolves this issue quite nicely Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/#findComment-3798748 Share on other sites More sharing options...
Dyemor Posted September 3, 2014 Author Share Posted September 3, 2014 The stormwolf does naturally sit on the stand at several angles due resting against the angled chair which resolves this issue quite nicely Its pretty much this that made me think about it. As the acrylic stand is basically a 'meta' stand to represent where it could be, am I allowed to customise it as much as the rest of the ship? If so its going to be a telescopic stand with a ball joint on it :) Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/#findComment-3798842 Share on other sites More sharing options...
Valor Posted September 3, 2014 Share Posted September 3, 2014 If you put it on the stand "backwards", it's already pointing downward at a decent angle. As long as my target isn't touching my base, I haven't had any issues getting LoS/firing arc on whatever I'm about to blow up. Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/#findComment-3798851 Share on other sites More sharing options...
eyeslikethunder Posted September 3, 2014 Share Posted September 3, 2014 The stormwolf does naturally sit on the stand at several angles due resting against the angled chair which resolves this issue quite nicely Its pretty much this that made me think about it. As the acrylic stand is basically a 'meta' stand to represent where it could be, am I allowed to customise it as much as the rest of the ship? If so its going to be a telescopic stand with a ball joint on it :) I think most players would consider this modelling for advantage Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/#findComment-3798856 Share on other sites More sharing options...
Dyemor Posted September 3, 2014 Author Share Posted September 3, 2014 The stormwolf does naturally sit on the stand at several angles due resting against the angled chair which resolves this issue quite nicely Its pretty much this that made me think about it. As the acrylic stand is basically a 'meta' stand to represent where it could be, am I allowed to customise it as much as the rest of the ship? If so its going to be a telescopic stand with a ball joint on it I think most players would consider this modelling for advantage Is 'modelling for advantage' a thing? I hadn't heard that term before but I guess it makes sense in that you could just use older and smaller models to get an LOS advantage. I dislike the idea though that depending on how you construct your flier, it may have a better or worse angle for ground attack. I tend not to play tournaments so we're having a discussion about what to do with it amongst our group. I was curious to see what others might have done or found. Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/#findComment-3798883 Share on other sites More sharing options...
eyeslikethunder Posted September 3, 2014 Share Posted September 3, 2014 I just didn't glue it to stand. it just happily sits on the stand in a variety of poses and angles I would not care too much but I know people who would Unfortunately modelling for advantage is a thing and has been abused Link to comment https://bolterandchainsword.com/topic/296215-vertical-firing-arc-on-stormfangstormwolf/#findComment-3798903 Share on other sites More sharing options...
