Dreadknight vs Titan
Rurik the blessed
Hi Brothers...
Yesterday i played against SW. He uses a Titan  Knight (The one with melta cannon) so...
i face my NDK with him... My NDK received two wounds from his melta cannon, and the Titan received two glancing hits by the Heavy Psycannon (he fails the invulnerable save).
SO... then the Titan Knight decided to assault... NDK failed overwatch. Both have I4, so we fights at same time...
I failed my previous "Force" activation (too bad). After rolling the dices, The Knight makes 12 wounds (due to the Force D rules).
So my NDK was doomed, but not before i struck some damage to him. I made my attacks, all hits... NDK had a Hammer , so S10 becomes 4 penetration hits. By the rules of vehicles attacks goes to his rear arc (not invul).
so, along with the previous two glancing, it was wrecked.
This was an epic battle. But i remain with the feeling that Titans are really fragile... We did it right?
https://bolterandchainsword.com/topic/296439-dreadknight-vs-titan/
Sadly not.  Its a walker, which means you strike the front arc!
You needed to get a 3 or more for a glance, and a 4 or more for a pen.  Sounds fun though!
Remember, activating force wouldnt have helped at all against the Imperial Knight.
Oh ... it will be the same against his front arc (i got 4, 5, 4, and 6 on the pens)... (he choose the side arc to have the invul).
The NDK seems to be a good Knight Hunter, as he is much more mobile (with personal teleporter) and with similar Ini he has a good chance to kill the Knight, even if he dies in return. As the NDK is much cheaper, I think it is worth it. But with invul save for the front arc I think the NDK has only a small chance to kill the Knight directly. It really depends on where the Invul save is located.
The Knights invulnerable save is only active against shooting attacks isn't it? So he shouldn't get a save at all when you're swinging.
Correct. Dreadknights are a fantastic counter to Knight-Titans and even normal Titans, due to their multiple S10 AP2 melee attacks, their WS5 (you hit on 3's), your own 4+ invul (assuming 'Sanctuary' is up), and your sheer speed. Plus you cost about half what they do, so its a very good trade even if you lose the DK in the process.
Just an observation, referring to a Knight as a Titan (not even 'Knight-Titan as many do') is somewhat confusing, as 'Titan' makes me think of Warhounds at the very least, which would do significantly better against a NDK (admittedly for more points) thanks to the availability of destroyer ranged weapons.
Also, why did you bother trying to get 'Force' off? Instant Death doesn't work against vehicles.
Yes, i was wrong with force... lucky i miss the activation... about the word "Titan", you're right, would be confusing, i will change that
As a player that uses his knight in almost all games I can honestly say that Knights are not that great in melee. Only 6 HP (I know, I know 6 shouldn't be with the word only) means that every Init 4 or higher walker or monstrous creature is a potentially viable threat and all it takes to slow me down is a lowly tactical squad that bothered to put a meltabomb on their sergeant. My Knight has been, at best, 50/50 in earning their worth because of those things but I see a Dreadnought army or, God help me, Wraithknights and I begin to regret the part of me that loves 50 meter tall walking death machines.
Same thing that makes me thing NDKs are awesome.
Knights are Knight-class Titans, hence why people refer to them as Titans and Knight-Titans. It doesn't matter how much nay Sayers try to change it, Knight are Titans. This is supported in fluff from their first introduction in Epic to their current version in 7th. Knights are referred to as the smallest class of Titans, Scout Titans, and single-crew versions of the larger Titans. They are Imperial Superheavy Walkers built to the same esthetics as all the other Imperial Superheavy Walkers. Get over it.
SJ
SJ
So what? They were out of the limelight for 20+ years. Which means that for the majority of 40k's lifespan, when people talk about Titans, they meant the engines of the Titan Legions, not the Knight Households.
Personally I find the Knight-Titan nomenclature a tad unnecessary, as simply calling it a Knight conveys all the desired meaning, but removing the Knight bit entirely only creates confusion.
It's a more extreme version of if you just say "Titan" there's no way of knowing at first glance if you mean a Warhound or a Warlord. You can say "I took my Warhound (or Knight) to the Apocalypse game" or "I took my Warhound (or Knight) Titan to the game". But if you just say "I took my Titan", unless the other person knows your collection, they then have to clarify what you meant.
The main reason to say 'Knight-Titan' instead of just 'Knight' is because Grey Knights are commonly referred to as 'Knights'. 'Knight-Titan' makes the distinction of 'oh you mean the giant walker guys, not the silver armor psyker guys'. And as IJ points out, GW uses such terms themselves.
