Nova_chron Posted September 9, 2014 Share Posted September 9, 2014 So I just bought two of the new space wolf dread kits and was wondering how many possible load outs there are with those two kits plus the forgeworld space wolves dread Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/ Share on other sites More sharing options...
ADHD-Spacewolf Posted September 9, 2014 Share Posted September 9, 2014 The ax/shield dread with a flamer, is the dread I use to dropod him Down right behind the enemy lines, and he at least draws fire, if not then once I had him chop two iron hand dreads inhalf then went to cleave the ironhand warlord in half It is defiantly a build worthwhile the flamer works to thin out any hordes that could charge him. Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3804956 Share on other sites More sharing options...
Jaarl Stormfang Posted September 9, 2014 Share Posted September 9, 2014 You don't get the flamer if you take the axe and shield. For my money, the two dreadnoughts I think are worthwhile are the axe/shield venerable in a drop pod for all the usual reasons, and the completely bare, 95 point multi-melta dread. Sub 100 points is a fantastic price for a model that is AV 12, 3 hull points and comes with a multi melta and a S10 weapon on a platform that can lock things in melee. There are all sorts of things that he is a threat or hindrance to, and he massively changes the dynamic of any attacks on your backfield units if he's present there, particularly deep strikers. Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3804977 Share on other sites More sharing options...
Frater Cornelius Posted September 9, 2014 Share Posted September 9, 2014 The dread with shield has a niche role in a SW list. He is very good against opponents that can not outrun him. His greatest strength is not his offensive power, but his defensive. He can eat one turn of shooting easily most of the time. So, drop him next to a Thunderfire Cannon, a Leman Russ sqaudron, artillery tanks, manned artillery (like grot gun or the eldar heavy support platforms), emplacements or heavy weapon units like broadsides. The enemy will either dedicate a lot of firepower or lose the unit, assuming his luck does not 1 shot kill him. Just make sure to drop him facing the threats with no possibility of being flanked and you are solid. It is also a very solid unit for Hammer and Anvil tactics (it being the anvil). Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3804979 Share on other sites More sharing options...
Nova_chron Posted September 9, 2014 Author Share Posted September 9, 2014 Are the bits in the box enough to equip 3 chassi? Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3804990 Share on other sites More sharing options...
Squark Posted September 9, 2014 Share Posted September 9, 2014 No, you can only make 2 Dreadnaughts with it. You've got some alternate bits, but you'd be missing key components if you tried to make a third dreadnaught out of it. Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3805006 Share on other sites More sharing options...
ADHD-Spacewolf Posted September 9, 2014 Share Posted September 9, 2014 You don't get the flamer if you take the axe and shield. For my money, the two dreadnoughts I think are worthwhile are the axe/shield venerable in a drop pod for all the usual reasons, and the completely bare, 95 point multi-melta dread. Sub 100 points is a fantastic price for a model that is AV 12, 3 hull points and comes with a multi melta and a S10 weapon on a platform that can lock things in melee. There are all sorts of things that he is a threat or hindrance to, and he massively changes the dynamic of any attacks on your backfield units if he's present there, particularly deep strikers. The axe and shield can have the flamer,because the axe and shield still has the stormbolter and you can replace the storm bolter with the built in heavy flamer. Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3805011 Share on other sites More sharing options...
Vlk Posted September 9, 2014 Share Posted September 9, 2014 You don't get the flamer if you take the axe and shield. For my money, the two dreadnoughts I think are worthwhile are the axe/shield venerable in a drop pod for all the usual reasons, and the completely bare, 95 point multi-melta dread. Sub 100 points is a fantastic price for a model that is AV 12, 3 hull points and comes with a multi melta and a S10 weapon on a platform that can lock things in melee. There are all sorts of things that he is a threat or hindrance to, and he massively changes the dynamic of any attacks on your backfield units if he's present there, particularly deep strikers. The axe and shield can have the flamer,because the axe and shield still has the stormbolter and you can replace the storm bolter with the built in heavy flamer. Nope. The DCCW with the built-in stormbolter gets swapped for the Axe and the Shield. Sorry. Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3805038 Share on other sites More sharing options...
Kasper_Hawser Posted September 10, 2014 Share Posted September 10, 2014 You can only make one Dreadnought out of one box, as each box only comes with one pair of legs and torso. However, the parts and bling can be combined with a basic SM dreadnought to make whichever 3 variants you want, Murderfang, Bjorn, Axe Shield or normal. Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3805213 Share on other sites More sharing options...
Nova_chron Posted September 10, 2014 Author Share Posted September 10, 2014 So with a total of 3 bodies as I have the FW wolves dread I will have enough bits to equip all 3 with most anything I like.... One is definitely beig built as bjorn I've had wolves for close to 10 years an have never once used him or even made a model to be him it is past time I fixed that Link to comment https://bolterandchainsword.com/topic/296521-dreads-and-what-to-do-with-them/#findComment-3805545 Share on other sites More sharing options...
