RastlinD Posted September 10, 2014 Share Posted September 10, 2014 So I just picked an old Armor Cast Warhound Titan which is already built and stands perfectly fine with out a base. However I think it will need a base both in terms of function and for playability in games. Do you guys have any suggestions on base size and material for it? Would the new Knight Titan base work or is it to small? Thanks. Link to comment https://bolterandchainsword.com/topic/296558-basing-a-titan/ Share on other sites More sharing options...
Dono1979 Posted September 10, 2014 Share Posted September 10, 2014 I havent based either of my Titans. The Base itself is not used rulewise at all, only for model stability purposes. For a warhound if it stands nicely go without the base, it makes FAR easier to move on the board in relation to terrain and other models. Any assault are still measured to the hull/feet. A reaver however.... I would look at some form of base Link to comment https://bolterandchainsword.com/topic/296558-basing-a-titan/#findComment-3806057 Share on other sites More sharing options...
