Ulrock Posted September 17, 2014 Share Posted September 17, 2014 I've recently switched from playing krieg to regular guard and I am wanting to play with an ADL this weekend. My issue is that do the enemy models also get a 4+ save? Or is this only if my models are further back from the line and not flush against it? Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/ Share on other sites More sharing options...
Wraith776 Posted September 17, 2014 Share Posted September 17, 2014 I believe it works just like any other wall or barricade in the game? Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3811037 Share on other sites More sharing options...
Jacinda Posted September 17, 2014 Share Posted September 17, 2014 It is by true line of sight. When you look from your firing unit to the target, is it 25% covered? If so then they get the cover save. We usually just assume any model in base contact can see over the wall but when in doubt, get close and look. Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3811327 Share on other sites More sharing options...
brother Vorn_GarDos Posted October 5, 2014 Share Posted October 5, 2014 Since this topic is aegis defense line. I thought it was best to place it here rather than make another thread. I have question about the aegis defense line. Can it still be used in the 7th edition? I do not see the points or stats for in in the new BRB. Does this mean that the aegis defense line can no longer be used? Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3825632 Share on other sites More sharing options...
Thoqqu Posted October 5, 2014 Share Posted October 5, 2014 There are rules for defence lines in the 7th ed rulebook, just no points and explicit rules for "aegis defence line". The rules for aegis defence line are in stronghold assault book and are still valid... Basicly nothing changed from the 6th ed except how interceptor and sky fire function together. *edit typos. Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3825661 Share on other sites More sharing options...
Quixus Posted October 5, 2014 Share Posted October 5, 2014 The only thing that changed is that someone at a tournament might insist that you produce the most recent rules for it (i.e. Stronghold Assault) a 6th Edition rulebook would not suffice even though the rules are the same (unless you want to add some upgrades like razorwire or an ammo dump). Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3825784 Share on other sites More sharing options...
The Librarian Posted November 9, 2014 Share Posted November 9, 2014 Can I now deploy the Aegis defense line in 4 x 2 seperate sections? "Each section of defence line must be placed in contact with at least one other section." And the faq telling us to deploy it in an unbroken chain is no more in 7th. Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3857488 Share on other sites More sharing options...
Quixus Posted November 9, 2014 Share Posted November 9, 2014 Where is this document you are taliing about? Neither the rulebook errata nor the Errata for Stronghold Assault mention anything about the ADL. [Hairsplitting]FAQ cannot change rules, only Errata can. So even if there is an FAQ saying to ignore the rules about the ADL this is just a houserule.[/Hairsplitting] Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3857506 Share on other sites More sharing options...
Leonaides Posted November 10, 2014 Share Posted November 10, 2014 Put section 1 down. Put section 2 down touching section 1. Section 3 must be placed touching either section 1 or 2, as section 4 is not on the board for section 3 to be placed adjacent to. Does this really need an faq? Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3858204 Share on other sites More sharing options...
Quixus Posted November 10, 2014 Share Posted November 10, 2014 While I agree it should be that way, what prohibits you from placing section 3 and 4 simultaneously touching each other? Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3858245 Share on other sites More sharing options...
Leonaides Posted November 10, 2014 Share Posted November 10, 2014 Because its impossible for a person to put both pieces down at exactly the same time. So one MUST be placed before the next. Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3858306 Share on other sites More sharing options...
Quixus Posted November 10, 2014 Share Posted November 10, 2014 If push comes to shove glue the two together. Then the two are connected even though one might not yet be in contact with the board. The rule does not specify that each section must be connected to one other section on the board. Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3858396 Share on other sites More sharing options...
Brother Casman Posted November 10, 2014 Share Posted November 10, 2014 Put section 1 down. Put section 2 down touching section 1. Section 3 must be placed touching either section 1 or 2, as section 4 is not on the board for section 3 to be placed adjacent to. Does this really need an faq? Do note that this interpretation implies that Section 1 cannot be placed on the board, as there is no other section for it to be placed adjacent to. As far as I'm concerned, if my opponent wants to split up the ADL sections, then placing them in groups of two satisfies the rule. I like seeing them as one unbroken chain, but sometimes the other terrain doesn't allow for it. Link to comment https://bolterandchainsword.com/topic/296824-aegis-defense-line/#findComment-3858578 Share on other sites More sharing options...
