aura_enchanted Posted September 19, 2014 Share Posted September 19, 2014 How does one recommend I go about painting beige deathwing using paints from the citadel line. Assuming I don't have access to any of those fancy spray primers (omitting black and white) that you would find in other countries. Link to comment Share on other sites More sharing options...
Larhendiel Posted September 19, 2014 Share Posted September 19, 2014 Slightly different approach, I made my whole army dark green including termies:http://www.bolterandchainsword.com/topic/282547-larhendiels-army/ Link to comment Share on other sites More sharing options...
Master Avoghai Posted September 19, 2014 Share Posted September 19, 2014 For me too.. I've made DW before the plain worlds hence black : http://www.bolterandchainsword.com/topic/270200-avoghais-5th-company-and-support-update-etl-adds-on/?p=3751635 Link to comment Share on other sites More sharing options...
Galthan Ironsturm Posted September 19, 2014 Share Posted September 19, 2014 DW pre-heresy style for me : http://www.bolterandchainsword.com/topic/275736-ironsturms-4th-co-ravenwing-up-black-knight-jetbike/?p=3741125 Because, Black is good ;) Link to comment Share on other sites More sharing options...
Interrogator Stobz Posted September 19, 2014 Share Posted September 19, 2014 White is Right Link to comment Share on other sites More sharing options...
Brother dean Posted September 19, 2014 Share Posted September 19, 2014 A search for "Deathwing Recipie" would probably bring up several different methods of painting tan/bone. Or even a look into "The Laws of the Lion" pinned at the top of this forum. Link to comment Share on other sites More sharing options...
Cactus Posted September 19, 2014 Share Posted September 19, 2014 Spray white, wash with Agrax Earthshade, glaze with thinned white. Link to comment Share on other sites More sharing options...
Avon Rekaes Posted September 19, 2014 Share Posted September 19, 2014 I take the easy way out and the Seraphim Sepia wash. My technique is to prime with white (obviously), then paint all the other color details first (red Deathwing icons, gold decoration bits, stone Crux Terminatus, metal gun bits, etc.) and then I carefully paint the Seraphim Sepia wash over the model, making sure to pool it in the recesses. I try to make only one pass over the top of the model, and paint the wash more liberally over the bottom, to emulate shading. Then I use Flayed One Flesh edge paint to highlight the edges. It can take a bit of practice to make the wash coat even, but after a while you'll get good at teasing it with your wash brush to pool where you want it to to create shadows. Here's my Deathwing Command Squad painted with this techinque: These were the first DW I painted this way, so you can see where I had trouble keeping the coat even, where there are darker splotches. Link to comment Share on other sites More sharing options...
Pbenner Posted September 19, 2014 Share Posted September 19, 2014 Here is mine; Spray on white primer Ushabti Bone base coat Deathwing Iconography (Mephiston Red) Cords (Scab Red) Chest Heraldry (Caliban Green) Gold and Bronze Seraphim Sepia Wash Boltgun Metal (Bolters, Hammers, Lightning Claws, Crux Terminatus) Mithril Silver (Swords, chains, etc) Bolter Casings (Red or Black) Nuln Oil Wash these parts Details (Eyes, keys, lenses, etc) Comes out decent, my hands shake but I make a good effort. Links in my Signature. Paul Link to comment Share on other sites More sharing options...
Prot Posted September 21, 2014 Share Posted September 21, 2014 How does one recommend I go about painting beige deathwing using paints from the citadel line. Assuming I don't have access to any of those fancy spray primers (omitting black and white) that you would find in other countries. Go to Imagine Games, downtown Wpg. They have the same Army Painter bone spray that I used on all the termies i've used here. I know you don't like painting but this is the best way to get your foundation going. Water down some Agrax Earthshade and work it into the crevasses, and do your best on the details. But yea, the easiest path is right down town at Imagine Games. :) Link to comment Share on other sites More sharing options...
SnakeChisler Posted September 21, 2014 Share Posted September 21, 2014 I've tried the white + bone and didn't like it that much as it looks washed out to me and I struggled to get enough definition on the highlights With painting there's a couple of approaches subtle and looking good from a distance, subtle gives you tons of close up detail but from a distance they can look a bit monochrome and that's why I went with the following to give a bit more definition as a group. I ain't the best of painters and my eyesight is one that needs glasses. Anyways a pic of a dread supplied as an example but it isn't that brilliant just an example Black undercoat (more to do with the rest of the model) Zandri Dust (Base Layer) basically a sand/tan color chosen over bone as bone doesn't cover as well and as said thought it looked washed out Reikland Flesh (Wash) chosen to give a redder tinge to the recesses Agrax looked OK but for me this looked a bit better, note GW washes have ink in them and look shiny while I put the wash all over I use a dry brush over the flatish areas to mop up pooling. Bone as a highlight and a blended layer from Zandri, you can mix the 2 and cover the clearer areas if you like What you end up with is this sort of thing Link to comment Share on other sites More sharing options...
elmo Posted September 21, 2014 Share Posted September 21, 2014 My method uses a mixture of paint manufacturers.. Army Painter Skeleton Bone spray Recesses in GW Agrax earthshade 1st highlight Vallejo Pale Sand 2nd highlight Vallejo Ivory Green: Dark Angels Green (still got 3 pots left over :)) Vallejo black ink 1st highlight DA green 2nd highlight Goblin green Red: GW Mephiston Red Vallejo Gory Red GW Agrax Earthshade Highlight with GW Blood red Mace head: GW Tin Bitz Vallejo black ink drybrush Vallejo Gunmetal Unfortunately a lot of the highlights have washed out in the photo but you get the general idea :) http://th09.deviantart.net/fs71/200H/f/2014/199/6/0/deathwing_knight_by_elmo9141-d7r7n3f.jpg Link to comment Share on other sites More sharing options...
