Wound allocation and flame templates
any template weapon only hits models under the template so a flame template can't hit any figure outside of its teardrop.
Not quite true. The order of Wound Allocation still holds. It is quite possible for Wounds to be applied to a model not "hit" by the template by virtue of being closer to the bearer.
It is more accurate to say: "A flame template can't hit any figure outside of the range and LOS of its teardrop."
In my opinion, the template is simply there for generating the number of hits. After that, any wounds generated are allocated to the nearest models first regardless if they are outside of the template (i.e to to left or right). However, don't the rules state that template weapons can not wound models out of range?
Kind of. Templates (and blast markers too, btw) are only used to count up the number of hits. Who takes the wound however can be models not touched by the template. It goes by who is closest to the firing unit. It is entirely possible in long gun lines that all of the wounds could be taken on models on the other end of the line who are outside of the template's range, yet closer to the unit than those who were hit by the template.
Weird, huh? Out of range of the firing model but in range of the unit. You could agre to pull them off by closest to the firing weapon but that is not how the rrules are written.
Anyway, those models under the template are hit, but wounds are allocated like any other.
That goes for any non-Blast weapon. You cannot Wound any models that are out of the range of the weapon being used.
Not quite. You cannot lay a Template over your own unit, so, the Template-user would have to be one of the closest to be effective, anyway. They would still have to be in the Template's Range, but not necessarily in Template User's Range.
Wrong.
Direct quote from the rules
"To work out the
number of hits, you normally need
to hold the template or blast marker
over an enemy unit or a particular
point on the battlefield, and then
look underneath (or through, if
using a transparent template) to see
how many models lie partially or
completely underneath. A unit
takes a hit for each model that
is fully, or even partially,underneath the template or
blast marker."
So it's clear, unless you are under the template you cannot be hit by it.
Well you do cause a hit for each model under the template, the rest of the shooting phase proceeds as normal.  Rolling to wound, allocation and saves, removing models starting from those closest to the firer, etc.
It is the unit that suffers the hits, not the specific models.  As noted in your quote:  "A unit takes a hit for each model under the template"
So Jacinda is right.
Template weapons do not alter wound allocation in any way, the first line of which is "First allocate a wound from the wound pool to the model closest to the firing unit"
You seem to be confusing hits for wounds.  Templates are used to determin the number of hits caused.  They generate a number.  Nothing more.  Once you have that number you can forget all about which models were under the template.  We don't care who was hit, only how many.
@Kristoff:  Torrent weapons are a prime example of the closest models to the firer not being under the template.  Additionally, you could have a unit positioned such that the firer would have to cover models *not* the closest to his unit.  I.e. firing at an angle to not cover intervening friendlies or having to position the template to cover the maximum number of enemy models.
Still, not the most common of events.
Especially now that the Heldrake has been nerfed fixed.  Knowing I'm going to charge after using my assault weapons, I will routinely place my flamers such that they aren't the closest to the enemies (to preserve them from Overwatch, should they survive the combat).  That makes for having to fire my flamers in what is not necessarily the best of angles.
