elciedery Posted September 30, 2014 Share Posted September 30, 2014 Recently I had a game with my friend's Dark eldar, and he uses Vect, barons and chimeras. I am not good at dark eldar, anyway, there was a kind of a bird(?) something that had T3 W5, and my furioso charged on it. Blood talons kill this model instantly, and there was a problem. How many additional attacks I can get? Link to comment https://bolterandchainsword.com/topic/297393-blood-talons-and-instant-death/ Share on other sites More sharing options...
Spagunk Posted September 30, 2014 Share Posted September 30, 2014 My understanding is that instant death is an outcome of a wound and doesn't impact the wound pool you already generated. That is to say, if you generated 4 unsaved wounds, the opponent allocates the wounds out to his squad even if one of those hits is going to instant death models. That still means you generated 4 unsaved wounds which generates 4 more rolls for blood talons. Since I don't remember if furiosos can accept challenges, these 4 additional rolls continue to get allocated to the squad the furioso attacked. It's essentially a blender at this point. Using this example, if the enemy squad has 3 models, the opponent allocates a single wound to two models and two wounds to the third model. If the strength of the attack is double the third model's toughness, the third is affected by instant death and dies outright regardless of the number of wounds left on that model. Now this does mean that if they allocated the 2 wounds to a single model, and that model suffers instant death from any of the two wounds, the extra wound goes away. However you still generated 4 unsaved wounds so you get to roll 4 more die rolls. Link to comment https://bolterandchainsword.com/topic/297393-blood-talons-and-instant-death/#findComment-3821533 Share on other sites More sharing options...
TheSauce Posted September 30, 2014 Share Posted September 30, 2014 Agreed. You ID the birds but only get one additional attack. When tallying assault results (which you shouldn't have to do because you wiped the whole squad :) ) you count the extra wounds caused by ID, so you would count all 5 or whatever. Link to comment https://bolterandchainsword.com/topic/297393-blood-talons-and-instant-death/#findComment-3821702 Share on other sites More sharing options...
tsijben Posted September 30, 2014 Share Posted September 30, 2014 You only get an additional attack for the Wounds caused by the Blood Talon. Instant Death says it reduces a model to 0 Wounds. So you don't actually cause more Wounds and thus you only gain one attack. Link to comment https://bolterandchainsword.com/topic/297393-blood-talons-and-instant-death/#findComment-3821758 Share on other sites More sharing options...
Spagunk Posted October 1, 2014 Share Posted October 1, 2014 You only get an additional attack for the Wounds caused by the Blood Talon. Instant Death says it reduces a model to 0 Wounds. So you don't actually cause more Wounds and thus you only gain one attack. That's not quite how it works. The reference about reducing a model to 0 wounds means that a single wound allocated to a single model will reduce the model's wounds to 0 upon failing their save. So instead of taking only 1 or 2 wounds off the model, it takes all of them. You already did 2 wounds to the model. The two wounds still count. If two wounds are allocated, and both are not saved (you are rolling ALL of your armor saves at the same time, right???), that's two unsaved wounds even though you only needed one to kill the model. Unsaved wounds are still unsaved wounds regardless of whether they were wasted on the model who took the wound. Link to comment https://bolterandchainsword.com/topic/297393-blood-talons-and-instant-death/#findComment-3822474 Share on other sites More sharing options...
elciedery Posted October 2, 2014 Author Share Posted October 2, 2014 Thanks everyone! Emperor be with you! Link to comment https://bolterandchainsword.com/topic/297393-blood-talons-and-instant-death/#findComment-3823347 Share on other sites More sharing options...
