Salvo weapons
Dread
So I just read the rules for this and want to see if I'm reading it correctly. So if you have a salvo weapon and move, you can only shoot at half of the maximum range? So a 24" range salvo 3/6 can only shoot 12" 3 shots if they moved in the movement phase. Is this correct?
That is correct. You also can't assault afterwards.
https://bolterandchainsword.com/topic/297534-salvo-weapons/#findComment-3824201
My biggest complaint about salvo is that we can't even snap fire the second profile if we moved. While I'm not sure it would fix psycannons, it would go a long way toward helping the mobility issue that power armor grey knights have when using them.
Nah, what would fix it is if GW took Salvo behind the shed and put it down. Salvo makes anything without Relentless trash, and anyone with Relentless don't care about it anyway. It's functionally worse than every other weapon profile (Assault, Heavy, Ordnance, Rapid-Fire etc). Ask Noise Marines, they usually just keep their bolters.
https://bolterandchainsword.com/topic/297534-salvo-weapons/#findComment-3825545
