Hello from Aviano AB Italy
Elf422
Hail and welcome to B&C, brother. I think you might benefit from checking through the subforums of the Community section of the site as you'll get a more likely response if you target the appropriate subforum. Also - it probably would help stating where you're aiming to play, as all you've said so far is that you're on an Air Base. ;)
