chaplain belisarius Posted October 9, 2014 Share Posted October 9, 2014 Hi, Am thinking of a slaanesh army and am thinking black and pink for the paint scheme. Am not much of a painter though! Is pink easy to paint? Thanks! Link to comment Share on other sites More sharing options...
Bryan Blaire Posted October 9, 2014 Share Posted October 9, 2014 There's even an army out there (may or may not be Slaanesh aligned) that is pink and black called the Angels of Ecstasy. Depending on what hue of pink you want, you could simply use GW's specific paints for pink: 1) Base Screamer Pink 2) Shade recesses w/Carroburg Crimson 3) Clean up w/Screamer Pink 4) Layer 1 w/Pink Horror 5) Layer 2 w/Emperor's Children 6) Drybrush edges w/Changeling Pink OR edge highlight w/Fulgrim Pink OR make your own edge highlight color by mixing 1:1 Emperor's Children:White Scar Link to comment Share on other sites More sharing options...
Forté Posted October 9, 2014 Share Posted October 9, 2014 Pink can be a pain. Especially over a black primer. Screamer pink is a good starting point but I recommend at least two thin coats rather than a think one and hoping it will cove well. What I will say though is don't be afraid to have fun when painting Slaanesh marines. You can pretty much justify any colours and combinations due to Slaanesh's excessive side. Link to comment Share on other sites More sharing options...
Xenith Posted October 9, 2014 Share Posted October 9, 2014 I'm doing some emperor's Children over a black undercoat. 2 coats Ceramite white, 2-3 thin coats emperors children. Having a pink basecoat will probably do wonders Link to comment Share on other sites More sharing options...
K0rtmer Posted October 10, 2014 Share Posted October 10, 2014 I've never actually painted pink, but I'd think it's nothing than can't be solved with some quick pre-shading (and taking steps, or layers, as forte suggests). Buy a can of white spray paint, be it primer or anything else, and give your primed-black models an extra coat of white from the top only. Then paint them. You'll have an easier time layering the pink and will likely also achieve some shading effects with next to no hassle. Link to comment Share on other sites More sharing options...
Disciple of Fulgrim Posted October 10, 2014 Share Posted October 10, 2014 GW's current scheme for pink works fine, but (in my exerience) requires mulitple coats of base and layers to get a good, bright pink - definitely a pain in the nether-regions. Priming with white (or maybe light grey, if you have an airbrush) can help (though then the black bits of your armor need to be basecoated) but no matter how you slice it, pink and black is a chore to paint. (If you do have an airbrush, then you might want to consider using it to prime in light grey, then basecoating the whole mini in the equivalent of GW's pink base - this cuts down on the time to do the pink armor bits, and basecoating black over pink isn't as hard as visa versa for the rest.) Link to comment Share on other sites More sharing options...
