Token Posted April 14, 2018 Author Share Posted April 14, 2018 (edited) Tried making a skull. Teeth area might be to wide.. Edit: Kinda learned using the knife tool, i Think its called. Edited April 14, 2018 by Token Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5055182 Share on other sites More sharing options...
Bjorn Firewalker Posted April 14, 2018 Share Posted April 14, 2018 The skull looks flattened, its cheekbones too wide for an adult human, but you can justify these features as deformities- mutations its original owner had- and mount it on a trophy rack to demoralize other Chaos worshippers. The runes look good, demonstrating good sculpting skills. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5055439 Share on other sites More sharing options...
Token Posted April 18, 2018 Author Share Posted April 18, 2018 Thanks for the constructive criticism! Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5059168 Share on other sites More sharing options...
Token Posted April 24, 2018 Author Share Posted April 24, 2018 Made a bolter where the ammo is ontop of the gun. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5063834 Share on other sites More sharing options...
Token Posted April 28, 2018 Author Share Posted April 28, 2018 Wip servoarm. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5066922 Share on other sites More sharing options...
Token Posted July 28, 2018 Author Share Posted July 28, 2018 Put together a banner guy, if its called that. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5132260 Share on other sites More sharing options...
Token Posted February 13, 2020 Author Share Posted February 13, 2020 (edited) Chaplain Dreadnought, probably needs more purity seals, maybe some runes to make it look more viking like. Edit: should replace the skulls on his legs for GW ones.. Edited February 13, 2020 by Token Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5476460 Share on other sites More sharing options...
Token Posted April 12, 2020 Author Share Posted April 12, 2020 Stormtalon, but the tail fin thingy on backwards, not that good. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5505203 Share on other sites More sharing options...
Yosef Hausakluif Posted April 12, 2020 Share Posted April 12, 2020 (edited) The Techmarine with the servitor tracks as legs is a great conversion. Really super impressed with you ability to create servo arms the way you do! Just watch the scale and size of them as when out of proportion to the model they come off as a bit cartoonish or a distraction. The ones on the dred look great but the same size ones on the marine model are a bit too large. A whole squad of the terminators you’ve got going would look sweet! Edited April 12, 2020 by Yosef Hausakluif Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5505472 Share on other sites More sharing options...
Token Posted April 17, 2020 Author Share Posted April 17, 2020 Thanks! I bought some servo arm stuff from Kromlech and Anvil Industries instead, i think the Kromlech ones are better. The Techmarine on tracks i dropped so its kinda damaged. Put some paint on a Termie. PowerHungryMonkey 1 Back to top Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5507737 Share on other sites More sharing options...
Token Posted April 24, 2020 Author Share Posted April 24, 2020 Some Squats. Trying to keep some viking theme to my marines and in Asatro they believe there are dwarves that are good smiths, so i thought some squats live side by side, maybe on a forgeworld, with marines and regular humans. And been thinking of combining my Iron Hands with Space Wolves, so been working on a Mechaninal Thunderwolf. Not sure what to use as spine/the part where the rider is, but maybe Necron Wraith parts. Should probably be shorter then the white plasticard thing is. It could maybe be made to be about the same size as regular Thunderwolfs. Angle kinda makes it look like he is sniffing his.. Tips on the Mechanical Thunderwolf would be good. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5511665 Share on other sites More sharing options...
Token Posted June 11, 2020 Author Share Posted June 11, 2020 Put together a mechanical thunderwolf, maybe the rider saved some techmarine, but his wolf died, atleast in body and the techmarine put its brain on some freeze thingy, built a new body and then put the brain in that body. Gave the marine a pelt and stuff. PowerHungryMonkey and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5539584 Share on other sites More sharing options...
Bjorn Firewalker Posted June 11, 2020 Share Posted June 11, 2020 The mechanical Thunderwolf looks most promising. I recognize a Warhound Titan's head; where do the other parts come from? Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5539753 Share on other sites More sharing options...
Token Posted June 12, 2020 Author Share Posted June 12, 2020 Body is Necromunda Ambot, the pipe that the marine sits on is plastic pipe, whatever it is called, and the tail is Necron Canoptek Wraith. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5539999 Share on other sites More sharing options...
Token Posted July 11, 2020 Author Share Posted July 11, 2020 Put together a Captain in Gravis armor. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5559981 Share on other sites More sharing options...
Token Posted November 29, 2020 Author Share Posted November 29, 2020 Put together a Dreadnought for my Iron Hands successor chapter, he could be a character Dreadnought, or just a normal Dreadnought. His name is Ulfgeir, which means Wolfspear. Tried to give him knotwork thingies on his shoulders, could perhaps be better. The Hammers of Thor are kinda a viking chapter, so i thought knotwork could make it look more like that. And a multimelta marine, gave him a viking like head to make him more viking and a bionic arm to be Iron handsy.. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5637522 Share on other sites More sharing options...
Token Posted April 22, 2021 Author Share Posted April 22, 2021 Had a multimelta from when i did a dev squad, thought a termie with a multimelta could be cool. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5691262 Share on other sites More sharing options...
space wolf Posted April 22, 2021 Share Posted April 22, 2021 Your stuff is wild, dude! I'm diggin it! Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5691326 Share on other sites More sharing options...
Token Posted April 23, 2021 Author Share Posted April 23, 2021 Thanks space wolf! NIce that you like it. Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5691513 Share on other sites More sharing options...
Doghouse Posted April 23, 2021 Share Posted April 23, 2021 I agree you've got some very imaginative conversions here. Good work! :tu: Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5691564 Share on other sites More sharing options...
Token Posted April 23, 2021 Author Share Posted April 23, 2021 Thanks Doghouse! Link to comment https://bolterandchainsword.com/topic/298301-stuff-by-token-probably-mostly-sw-and-ih/page/2/#findComment-5691584 Share on other sites More sharing options...
