Grim Dog Studios Posted October 24, 2014 Share Posted October 24, 2014 Just wondering what everyone's favorite spray primer was? I have a couple of old cans of GW black, but they are like two years old now so I'd rather not use them. I've been looking at the army painter ones and they look quite good. Looking for either a black one or a dark grey one, as I'm painting 30k wolves and that could cut out the step of base coating them. Army painters grey primer looks a little too light for the shade of grey that I'm after however. Any help would be much appreciated! Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/ Share on other sites More sharing options...
Grand Master Belial Posted October 24, 2014 Share Posted October 24, 2014 Rust-o-leum from local DIY home builder. Has a couple colors that are darker than Army Painter and it comes with a matte finish. Just have to be extra careful to avoid the fuzz though. And it is cheap. If you do go with the lighter gray, it is easier to wash it darker than base coating up. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843209 Share on other sites More sharing options...
Aqui Posted October 24, 2014 Share Posted October 24, 2014 I've used GW's sprays and I've found them to be okay However, if you're looking for more spray consistency when spraying, more paint for less money, more colours, then I suggest giving a trip to Halfords serious consideration. Halfords Black Matt Primer (£7.49 for 500ml) compared to getting Chaos Black (400ml for £9.80). the nozzle doesn't get clogged nearly as bad either I've recently used a red one for my Space Hulk models (painting as Flesh Tearers) and it went on very well...I just should have checked the label as it was a metallic paint I bought Still, the slight metallic effect looks quite good! Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843234 Share on other sites More sharing options...
Grim Dog Studios Posted October 24, 2014 Author Share Posted October 24, 2014 Cheers for the quick replies! Rust-o-leum from local DIY home builder. Has a couple colors that are darker than Army Painter and it comes with a matte finish. Just have to be extra careful to avoid the fuzz though. And it is cheap.If you do go with the lighter gray, it is easier to wash it darker than base coating up. Never heard of that paint, never seen it either! I'll keep my eye out though! I've used GW's sprays and I've found them to be okay However, if you're looking for more spray consistency when spraying, more paint for less money, more colours, then I suggest giving a trip to Halfords serious consideration.Halfords Black Matt Primer (£7.49 for 500ml) compared to getting Chaos Black (400ml for £9.80). the nozzle doesn't get clogged nearly as bad either I've recently used a red one for my Space Hulk models (painting as Flesh Tearers) and it went on very well...I just should have checked the label as it was a metallic paint I bought Still, the slight metallic effect looks quite good! Just looked through the halfords paint and noticed they do a matte grey one, just wondering if anybody had experience with that one and could comment on how dark it is? Cheers, James Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843245 Share on other sites More sharing options...
Aqui Posted October 24, 2014 Share Posted October 24, 2014 I've only used the Matt white and black so far. I'm considering using the grey myself. I got the heads up from another member of the board, (who uses the grey themselves), but I've forgotten who it is Hopefully, they will post Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843262 Share on other sites More sharing options...
Son of Carnelian Posted October 24, 2014 Share Posted October 24, 2014 GW remains the best in my opinion. A bit overpriced but it has the perfect coverage and consistency. Army painter however, always comes out too thick. I would not recommend that at all. I've heard good things about the Wal-Mart brand primers, but my personal experience with them bordered on disastrous. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843277 Share on other sites More sharing options...
Brother Callius Posted October 24, 2014 Share Posted October 24, 2014 Vallejo spray primers has always worked for me, not to expensive and no problems with the nozzle what-so-ever. They also dry to a coarse finish so the other paints has something to stick to without clogging up the details. I use it primary on FW resin and have had no problems other than the standard mold release agent... Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843290 Share on other sites More sharing options...
nimrod451 Posted October 24, 2014 Share Posted October 24, 2014 I like using the Citadel GW Black Primer - Its more expensive, but I like it. I've tried other stuff and had bad luck. ... I'm not sure if this a product of being what I've always used or not though. I didn't like the Army Painter colored primer - it dried in this like.. weird rubbery texture that I found.. distressing.. and seemed a bit think for my liking. Again this might be due to lack of experience with it though. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843379 Share on other sites More sharing options...
BFeeder Posted October 24, 2014 Share Posted October 24, 2014 Just looked through the halfords paint and noticed they do a matte grey one, just wondering if anybody had experience with that one and could comment on how dark it is? Cheers, James It's excellent. For darkness, I'd say it's similar to the old Codex Grey, so it's a perfect undercoat for anything that isn't predominantly black. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843419 Share on other sites More sharing options...
SW1 Posted October 25, 2014 Share Posted October 25, 2014 I find good old PoundShop does tins of matt car spray and the grey or black look absolutely fine. Buy a tin for £1 and give it a test spray. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3843670 Share on other sites More sharing options...
Forté Posted October 27, 2014 Share Posted October 27, 2014 I use Halfords black, grey, and white. Love them. Spray a little further away than GW though. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845252 Share on other sites More sharing options...
Brother Amarel Posted October 27, 2014 Share Posted October 27, 2014 Just looked through the halfords paint and noticed they do a matte grey one, just wondering if anybody had experience with that one and could comment on how dark it is? Cheers, James It's excellent. For darkness, I'd say it's similar to the old Codex Grey, so it's a perfect undercoat for anything that isn't predominantly black. I concur about its quality and colour comparison. I use it for everything which doesn't require a black primer (unless it's really cold out, then I use Gesso, but that doesn't help much with this thread :)). Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845258 Share on other sites More sharing options...
Grim Dog Studios Posted October 27, 2014 Author Share Posted October 27, 2014 Cheers guys, think I'll pop down to halfords after work tomorrow and pick up some of the grey primer! Hopefully it's the shade I'm looking for and if not I can just basecoat the marines anyway :) Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845263 Share on other sites More sharing options...
Daemon2027 Posted October 27, 2014 Share Posted October 27, 2014 I also use Halfords grey. Similar price to GWs but a larger can. Make sure to shake it well before spraying. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845334 Share on other sites More sharing options...
Jolemai Posted October 27, 2014 Share Posted October 27, 2014 Another nod for Halford's Matt Black. When I get around to painting something that needs it, I will be purchasing their grey version. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845346 Share on other sites More sharing options...
Stercus Posted October 27, 2014 Share Posted October 27, 2014 The halfords range is good. Leaves a really matte finish without any shininess. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845415 Share on other sites More sharing options...
The_Chaplain Posted October 27, 2014 Share Posted October 27, 2014 Does anyone have any experience with Vallejo's "Plastic Soldier" spray primers? I have been less than impressed with my experiences using Army Painter's spray primer in the past, and my LGS carries the Plastic Soldier brand. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845656 Share on other sites More sharing options...
Gurth Posted October 27, 2014 Share Posted October 27, 2014 I used to use Motipp brand car primer, which had excellent coverage and a good matt finish. Note my use of the past tense: the last couple of years it’s gone to poor coverage, a smooth semigloss finish, and worst of all, lifts off plastic models if I apply masking tape over it (when one of the functions of a primer is to adhere well to the material). I’ve since switched to Army Painter white primer and found it to be much better: good matt finish, good coverage and doesn’t lift with tape. Link to comment https://bolterandchainsword.com/topic/298415-best-spray-primer/#findComment-3845711 Share on other sites More sharing options...
