Primarch Arena
AfroCampbell
Survivable I'd probably plump for Ferrus or Vulkan, they're the "tanking" Primarchs we've seen so far.
As for killing, Horus/Angron/Curze are the three stand outs for me.
Weakest.....probably Lorgar
Mortarion surely has to be in with a shout for most durable as well.
From my own tests (which should be taken with some salt since I had them all go against a lost Primarch and I've only gotten through half of them)
Horus with his Disabling Strike is by far one of the most dangerous Primarchs. Just a couple of those wounds and soon any Primarch will be hitting him like a guardsman.
Mortarion is indeed one of the toughest out there so far.
And Lorgar (Transcended) is fairly dangerous since he can just grab Invisibility. Whether or not it goes off is another matter.
Some of the weakest in one-on-one combat is Corax and Alpharius since Corax only has a 5+ Invul, while Alpharius is supposed to pick and choose his own fights since he's hidden until he doesn't want to be.
I feel like Angron is kinda underrated.
Seems like he would have some serious potential to wound Horus on that first round, since he'd be hitting first on a re-rollable 3+ and wounding on a 2 with at least six attacks correct?
Hmm... That is only an average of two wounds after Horus' 3++ though.
On the other hand, Horus would only cause an average of a single wound to Angron though. Now I'm even more undecided than before I sat down to do the math :(
To:dr - Angron is Killy, Horus might have a shot, Kurze wins by default ^_^
He "could" be killed by howling banshees in the same way they "could" glance a leman Russ to death from the sass end.
Chances are more likely they go first, hit with one out of every three attacks, wound with none of them, then have a good 6-8 of their number butchered, fail the break check and get curb stomped.
Then again, Angron is a lot more points than banshees. ^_^
Angron would pretty much win any primarch fight if he was allowed to Grind some kills prior to get hit maximum +1 Attacks per unit destroyed by him.
18 Attacks on the charge would be unsurvivable barring RNGesus intervention.
"And may the dice be with you, brother."
Yeah if you give Angron some red shirts to eat up, then he can max his attacks and probably beast Horus in a round or two.
The cause for concern is that Horus' talon is AP3 and can easily eat through Angrons saves.
Most of these primarchs actually wind up like the praetor stalemate that happens on lower levels. The two models just continually beat on each other ad infinitum until one of them pulls of a really lucky go.
Lies, they can't plink a Russ. You liiiiieeeee. But yeah, I know what you mean. It just tickled me somewhat. That and I couldn't think of anything else with a power sword when I was typing...
 You ain't just whistling dixie.
Yeah, essentially both of these big beatsticks will face each other in combat because neither side can afford to have the other run around with a primarch through their lines.
But this does technically bring about balance, if not a stalemate.
Just finished going through 3 rounds with him and kinda. He does bring good things to the table and will massacre most space marines against him, but he is a 'balanced' fighter. A bit early, but it feels like Perturabo fits in the same area as he does. Both have reasonable defenses, between Perturabo's 3+ Invul and Dorn's "you can't wound me higher than a 3+" you can't quickly overwhelm them without the dice being weird. Between Forgebreaker and Sundering Blow, both of them can hit hard, but neither of them throw out a lot of attacks, both being just 4.
So yeah. They feel like they balance their offense and their defense, so they don't excel at either unlike Angron and Mortarion, while Horus just has all of the excellent wargear combined with decent stats.
I notice that Rogal Dorn isnt mentioned in either groups. Is he so middle of the road? I know his main strengths are in buffing his army but I thought he was still reasonably potent? (never fielded him though).
He has very few attacks and doesn't have the option of striking at his own initiative, so against the more combat proficient primarchs he struggles. Additionally, he only has a 4+ invulnerable, but can't dish out masses of wounds to compensate (eg Angron). I'd say in terms of combat ability he is middle-ish. He's far from the flashiest in combat, in line with his personality I suppose but I've heard a lot of disappointed (whether rightly or wrongly is entirely up to you) IF players as a reuslt of his rules
