Need some help devising a way to paint up Luna Wolves.
So I tried painting up a Luna Wolf for my 40k army earlier today. Let's just say it ended badly. I know I need to thin my paints, etc, and I've got brushes and gel medium on order. However, does anyone know any tutorials for painting Luna Wolves from a black primer base? In addition to the black primer, I've got a slate grey from DecoArt's Americana range, Vallejo's Wolf Grey Game Color, Vallejo's White Primer Game Color, GW Skull White, Agrax Earthshade and Nuln Oil. As for the miniature I painted today, I tried to emulate this and it came out like this. Besides thinning my paints, what else can you all suggest I do to get some tabletop quality Marines?
Painting White on a black base color is a pain in the ass.
If you prime black and want to go to white you first need some layers of grey, brown depending if you want a warm or cold white.
I would suggest get some thin layers of Ulthuan Grey on your miniature and then go to white
If you *have* to prime in black, your first step should be 2-3 thinned coats of Ceramite White, GWs base paint. Then from there either a Brown wash/glaze or Grey/Blue wash/glaze depending on desired finished colours. Then after wash has dried (30min minimum), another coat of Creamite White followed by White Scar highlights.
Cheers,
Jono
This is true, if you are doing the white with a brush. In my experience, white paint is more transparent than black, which is usually very opaque, so it's a horrific process of tons of very thin white coats to build up that opaqueness and get a good base color.
If you spray a plastic or metal figure with white primer, it can take several coats to get a good foundation as well, and even then, it can still be an off-white, more like a light grey color. I had a happy accident some years ago when I wanted to try out a paint scheme with a white base coat, but the only thing I had assembled at that moment was a marine I had already primed black. Being impatient and not wanting to assemble, wash, and dry another one, I just snatched up the one with the black primer and hit it with the can of white primer - lo and behold, with two very thin coats sprayed on, the white was brighter than anything I had been able to achieve before just using white primer.
I'd give that a try and just work on shading the white instead of the building up of numerous layers of ever-lighter greys until you get to white.
I actually prefer painting white over a black undercoat and then going through a process of grey to whites. Usually adding a basecoat of dark greay and to layers of a medium to light grey neutralize the black undercoat. After that its all about adding a mix of light grey and white.
The final stage depends on what kind of white you prefer. I like off-white colours so I never go pure white, only for highlighting, which means my white colour is usually a mix of 1:3-4 celestial grey and white. Of course if you like pure white, you should go for that.
But it takes a loooot of time.
