markham82 Posted November 14, 2014 Share Posted November 14, 2014 So The way I understand your flyer can end its move over your own ground units and 1" away from enemy units. So if you end over your own unit does the ground unit go on the flyers base or is it just the part of the hull sticking out beyond the base that can be over that ground unit. For enemy units, can they move "through" the flyer by going under it if they fit or do they have to go around. Link to comment Share on other sites More sharing options...
Acebaur Posted November 14, 2014 Share Posted November 14, 2014 No, pg 84. Your base still has to be 1" away from enemy models. The only thing that rule allows you to do it have the actually model above other units as most flyers are significantly larger than their bases. Link to comment Share on other sites More sharing options...
