Donkalleone Posted November 25, 2014 Share Posted November 25, 2014 A Thunderstrike consist of WG, WGTDA and a Droppod. It also states if a reserve roll is made all of them come on the table.Droppod assault automatically Passes reserves and comes round 1. Does this mean the whole formation arrives round 1 when DP is part of the first wave? Had to make own Thread since no one answers in FAQ Link to comment https://bolterandchainsword.com/topic/299684-thunderstrike-formation-question/ Share on other sites More sharing options...
Z00Z Posted November 25, 2014 Share Posted November 25, 2014 I believe RAI would be that you cant bring it in automatically turn 1 as you have not rolled for reserves. I know auto entry dp rules but I dont believe it iscwhat is intended. If it is your only dp, only the wg pa will come on. At least thats how I would play it Link to comment https://bolterandchainsword.com/topic/299684-thunderstrike-formation-question/#findComment-3870972 Share on other sites More sharing options...
Frater Cornelius Posted November 25, 2014 Share Posted November 25, 2014 If the DP and the TDA come on separately, then you can not benefit from the twin-linked rule seeing as the whole formation did not arrive. This is an issue without an answer and needs to be talked about with the opponents. Until a FAQ comes out, this is a very sticky situation. We can all argue until the eagles choke, we will not arrive at an answer. This needs official clarification. Link to comment https://bolterandchainsword.com/topic/299684-thunderstrike-formation-question/#findComment-3870981 Share on other sites More sharing options...
Oz of the North Posted November 25, 2014 Share Posted November 25, 2014 This is still up in the air, but a possible way to mitigate it is throw the WGTDA in a pod and make sure you have 3 then 2 can come on first turn. Possible solution to try and solve some arguements. Otherwise I would say you might just have to wait until turn 2 to get your drop pod. Link to comment https://bolterandchainsword.com/topic/299684-thunderstrike-formation-question/#findComment-3870990 Share on other sites More sharing options...
