super glued plastic+resin
Anyways i've got some forgeworld resin stuff ive mixed with standard space marine plastic
they've been superglued and unpainted
My question is guys what would be a good soak to dissolve or weaken the superglue as i wanna use the forgeworld stuff for space wolves
https://bolterandchainsword.com/topic/300118-super-glued-plasticresin/
It might be bad glue jobs, but I have noticed, when I was stripping the bad undercoat from some 2nd Hand Foreworld models.
When they were soaking in the Fairy power spray, bits started loosening off quite well, although waybe the warm water assisted too.
Its how I lostthe stupid chain fist pieces of my tartaros terminators and ended up using GK Halberd heads instead.
Hey I have the same thing but in my case I need a glue that works on resin and plastic. I have an older chaplain (the $16.95 model) in which I need to glue his left arm on but I also need to attached a current/plastic jump pack to. I have GW plastic glue thin and it didn't work, and I tried Gorilla Glue. ??
Thanks.
