appiah4 Posted December 9, 2014 Share Posted December 9, 2014 I have a spare pair of Furioso arms lying about; if I bought a Chaplain Dreadnought from Forge World, would they be compatible? I don't want to end up with incompatible kits.. Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/ Share on other sites More sharing options...
Chaeron Posted December 9, 2014 Share Posted December 9, 2014 From memory, never had an issue. Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/#findComment-3884239 Share on other sites More sharing options...
knife&fork Posted December 9, 2014 Share Posted December 9, 2014 I have a spare pair of Furioso arms lying about; if I bought a Chaplain Dreadnought from Forge World, would they be compatible? I don't want to end up with incompatible kits.. The pegs are compatible. GW dread arms tend to be slightly bigger than FW ones, but it shouldn't be a problem. Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/#findComment-3884311 Share on other sites More sharing options...
appiah4 Posted December 9, 2014 Author Share Posted December 9, 2014 Perfect. :) Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/#findComment-3884333 Share on other sites More sharing options...
Kilofix Posted December 9, 2014 Share Posted December 9, 2014 FW Dreads are all MK IV. Which means that they have slots on either side of the torso that can fit a targeter and the secondary Storm Bolter or Flamer weapon when using a Fist. These MK IV Dreads can take GW MK V arms, but you won't have the pieces to fit those body slots. Instead, the SB or Flamer will be on the GW MK V arm / Fist itself. Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/#findComment-3884377 Share on other sites More sharing options...
appiah4 Posted December 9, 2014 Author Share Posted December 9, 2014 I will fill the torso weapon mounts with milliput and magnetize weapons onto plastic furioso arms. Thanks for the heads up. Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/#findComment-3884388 Share on other sites More sharing options...
Naryn Posted December 9, 2014 Share Posted December 9, 2014 Speaking from experience, the Ultramarines Venerable Dreadnought and the MK IV Ironclad weren't hard to put Furioso and Ven Dread arms on at all. The pegs were the same size, too, so it's probably standard across all the FW dreads. Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/#findComment-3884644 Share on other sites More sharing options...
NovemberIX Posted December 9, 2014 Share Posted December 9, 2014 I've done exactly what you're asking about, you may need a bit of green stuff or millput to get things to stay in place. At least that was my experience, but it'll look well worth it. Link to comment https://bolterandchainsword.com/topic/300194-are-fw-and-gw-dreadnought-bodyarms-compatible/#findComment-3884727 Share on other sites More sharing options...
