Taghmata Omnissiah 1500/2000 points
LaborerDNA
HQ
Magos Prime (275pts)
Archmagos Prime, Cyber-familiar, 2x Cyber-occularis , Djinn-skein, Lachrimallus, Machinator Array , Paragon Blade , Rad Grenades
Troops (855pts)
Adsecularis Covenant (105pts)
Induction Charges, Revenant Alchemistry, 20x Tech-thralls
Thallax Cohort (215pts)
Destructor, Multi-melta, 4x Thallax
Destructor, Multi-melta , 4x Thallax
Addition to 2000pts limit - Adsecularis Covenant
Induction Charges, Revenant Alchemistry, 15x Tech-thralls, The Rite of Pure Thought
Elites (100pts)
Tech-Priest Auxillia
3x Flamer, 4x Servo-automata, Upgrade one Adept to Magos Auxillia,Lacyraemarta
Fast Attack (240pts)
Crusade Fleet Support Wing
Primaris-Lightning Strike Fighter
Ground-tracking Auguries, Ramjet Diffraction Grid, 2x Twin-linked Missile Launcher, Two Kraken penetrator heavy missiles
Heavy Support (130pts)
Krios
Lord of War (400pts)
Addition to 2000pts limit - War Machine Detachment
Mechanicum Cerastus Knight-Lancer
  On 12/15/2014 at 12:35 PM, LaborerDNA said:
It seems that AdMech lists aren't really popular here, so I thought I can contribute a bit.
I thought they are not popular here because they have their own branch: http://www.bolterandchainsword.com/forum/191-adeptus-mechanicus-army-lists/
Can't really comment on the list, as due to not having the 30k books, I don't even know what all of those words mean. However, I'll give you some general forum advice. Remove the points costs for individual pieces of wargear, as it's against forum rules.
I.e. this is fine (showing total unit cost is ok, just not individual weaponry points etc) .
(Destructor, Multi-melta, 4x Thallax)
Dallo
First things first, remove individual points costs for wargear options. For example:
4x Thallax, Destructor, Multi-melta
...would be a more appropriate format. Further, I would remove one Thallax Cohort, reduce the other two to units of three (in total you should have freed up 285 points (215 + 35 + 35)) so as to better allocate weapons per points spent (even MSU Cohorts are durable for mandatory troops). I would then include a Castellax maniple into the list, preferably with the Darkfire Cannon in there somewhere for (very) long-range harassment and the ability to hit various units hard (S7, AP2, Lance, Heavy 2).
I've little to contribute other than that. I'd probably try and trim down the points cost on your Magos and wouldn't bother with the Induction Chargers for the Thralls (try and keep them as cheap as possible). Don't know much about the fighter with regards to capabilities and optimal loadouts and the like, so nothing in particular to comment on there. If you cut out enough points you could probably find room for a Thanatar Siege-automata.
  On 12/15/2014 at 12:39 PM, LaborerDNA said:
HQ
Troops (855pts)
Elites (100pts)
Krios
I agree with Chronozoah,but just adding my own twist,make your Tech thralls bare bones.They wont do any huge damage just to secure objective.So pump those remanining points on either castellax or buffing it more with thallax.
^ Definitely a worthy consideration. If all they're going to be doing is securing backfield objectives, for example, you may want to keep them as cheap as possible.
I will add that the Lance rule won't actually come into effect very often and thus will barely benefit the unit in question anyway. At BS4 you're only stripping an average of 0.4 hull points. There are much better targets for S7 AP2 weapons with Blind.
