Deschenus Maximus Posted December 21, 2014 Share Posted December 21, 2014 I just noticed that the Angel's Wing doesn't specify the matter in which a unit Deep Strikes when one uses it's ability. So: Sanguinary Priest - The Angel's Wing, Valour's Edge, The Crown Angelic, The Veritas Vitae 10 Assault Terminator - TH/SS for all Is this awesome? yes/yes Link to comment Share on other sites More sharing options...
bigted Posted December 21, 2014 Share Posted December 21, 2014 If this is correct... awesome! Link to comment Share on other sites More sharing options...
Landrick Posted December 21, 2014 Share Posted December 21, 2014 that has been my understanding Link to comment Share on other sites More sharing options...
veneratedaniel Posted December 21, 2014 Share Posted December 21, 2014 "Only one of each relic of Baal may be taken per army. " - yep ok you have it there "A model may replace ONE weapon with ONE of the following" - so ok there are 2 ways you can see this 1 - you can replace only one weapon only 2 - you can replace one weapon for one weapon even if you take it in the second manner of speaking, you will only be able to swap over for 2 relics at the most option 1 is something along the same lines that happened to the chaos marines dex and created many arguments upon the lack of wording that was used. Link to comment Share on other sites More sharing options...
Noctus Cornix Posted December 21, 2014 Share Posted December 21, 2014 "Only one of each relic of Baal may be taken per army. " - yep ok you have it there "A model may replace ONE weapon with ONE of the following" - so ok there are 2 ways you can see this 1 - you can replace only one weapon only 2 - you can replace one weapon for one weapon even if you take it in the second manner of speaking, you will only be able to swap over for 2 relics at the most option 1 is something along the same lines that happened to the chaos marines dex and created many arguments upon the lack of wording that was used. Its been proven that you can take as many relics on a person as you like. As an example, look at the Crimson Slaughter supplement. If you want to create a Chaos Lord to represent Kranon the Relentless he takes like... 3 or 4 relics. Link to comment Share on other sites More sharing options...
Landrick Posted December 21, 2014 Share Posted December 21, 2014 "Only one of each relic of Baal may be taken per army. " - yep ok you have it there "A model may replace ONE weapon with ONE of the following" - so ok there are 2 ways you can see this 1 - you can replace only one weapon only 2 - you can replace one weapon for one weapon even if you take it in the second manner of speaking, you will only be able to swap over for 2 relics at the most option 1 is something along the same lines that happened to the chaos marines dex and created many arguments upon the lack of wording that was used. this isnt even what the OP is talking about. He is saying that a JP priest attached to Termies would reduce the scatter even though it is in theory "two different types" of deep strike Link to comment Share on other sites More sharing options...
ThatOneMarshal Posted December 21, 2014 Share Posted December 21, 2014 I want to try this now imagine 10 assualt terminators in your opponents face turn one right in front of a vindicator. Though you can storm sheilds to minimize the damage. Link to comment Share on other sites More sharing options...
21stPrimarch Posted December 21, 2014 Share Posted December 21, 2014 How would they get there turn one? Turn 2 at earliest Link to comment Share on other sites More sharing options...
Landrick Posted December 21, 2014 Share Posted December 21, 2014 attach a GK libby... T1 ftw Link to comment Share on other sites More sharing options...
veneratedaniel Posted December 21, 2014 Share Posted December 21, 2014 "Only one of each relic of Baal may be taken per army. " - yep ok you have it there "A model may replace ONE weapon with ONE of the following" - so ok there are 2 ways you can see this 1 - you can replace only one weapon only 2 - you can replace one weapon for one weapon even if you take it in the second manner of speaking, you will only be able to swap over for 2 relics at the most option 1 is something along the same lines that happened to the chaos marines dex and created many arguments upon the lack of wording that was used. Its been proven that you can take as many relics on a person as you like. As an example, look at the Crimson Slaughter supplement. If you want to create a Chaos Lord to represent Kranon the Relentless he takes like... 3 or 4 relics. Fair enough I haven't seen that sup, just saying to check the meta of the area before getting too excited, just what I would do over here. Link to comment Share on other sites More sharing options...
Theduke08 Posted December 21, 2014 Share Posted December 21, 2014 I hope this gets FAQ'd to reflect that it only works arriving via Jump pack... seems like a stretch that this should work for anything but... Link to comment Share on other sites More sharing options...
Deschenus Maximus Posted December 21, 2014 Author Share Posted December 21, 2014 seems like a stretch that this should work for anything but... I agree. "As long as the bearer is in a unit composed solely of Jump Infantry, you may reroll the scatter dice when deep striking" or something should be added. Link to comment Share on other sites More sharing options...
mysteriousmaskedmystery Posted December 21, 2014 Share Posted December 21, 2014 i believe it specifically mentions units like skimmers and such being affected by the rule, as well as flyers being affected by the re-rolls but not the scatter obviously. it's clear it's intended to affect units other than jump infantry. now if you mean, it shouldn't allow units with different types of deep strike to drop in together, well, if that's what they wanted they should have that in the big rule book so that it would be that way for everyone, rather than specifically targeting Angels. Link to comment Share on other sites More sharing options...
Deschenus Maximus Posted December 21, 2014 Author Share Posted December 21, 2014 i believe it specifically mentions units like skimmers and such being affected by the rule, as well as flyers being affected by the re-rolls but not the scatter obviously. it's clear it's intended to affect units other than jump infantry. now if you mean, it shouldn't allow units with different types of deep strike to drop in together, well, if that's what they wanted they should have that in the big rule book so that it would be that way for everyone, rather than specifically targeting Angels. I think you are confused. The Angel's Wing is a Relic that allows you to reroll your scatter on Deep Strike. What you are thinking about is the Descent of Angels warlord trait, which is something else entirely. Link to comment Share on other sites More sharing options...
