My next BA list
Jorre
1850 points
Commander Dante
Command Squad (Dante Delivery Unit)
3 x Veterans with Storm Shield and Meltaguns
1x noviate
1x Champion
Mephiston
LVL 2 Librarian
Gallians Staff
Jump pack
10 man Tactical in pod ( Can combat after delivery for multi rolls)
Heavy flamer
Meltagun
Sergeant has 2 x infernus
5 man Tactical in Rhino (Rear objective holder)
Missile with flak
2 x Furioso in pod
Frag cannon + melta with Magna Grapples
2 x 5 man assault squads in pods
2 melta and 2 infernus pistol each
1 x Sicaran Battle Tank with Lascannons (Thanks for drawing my attention to this awsome Tank Morticon!)
I am going to have to build/paint this force almost from scratch as I either don't have the models or am not satisfied with them. So any thoughts on the list would be appreciated!
It is melta heavy, but my meta has a lot of mech in it. I also need to be able to place a melta squad on both sides of naty things like Imperial Knights to avoid there sheilds!
I was going to put Mephy with an assault squad, but I could also sub one assault squad out for a DC unit to go with him
https://bolterandchainsword.com/topic/300830-my-next-ba-list/
Can't comment on the rest of the list but have you thought about scout squads instead of the rhino tactical squad? Cheaper and if you give them camo cloaks they become more resilient as well.
It's a good idea and I have thought about trying scouts.... But I really hate the models! So much more kitbashing potential with normal marine parts!
I'd replace the infernus pistols with combi melta, will save you 60 points and give you the same melta range all on 3.
This does free up a lot of points, what do you think I should spend them on though ?
It does save points but it costs you shots. You get 3 shots on the first turn instead of 4 and then only 2 on subsequent turns. Even with melta guns, you only have a 1/3 chance of actually killing a tank with a penetrating hit so you need to consider that you may have to hull-point a tank to death.
3 shots will give 2 hits on average and to my mind is just not enough to reliably kill a tank. The assault squads are only 5 guys but with dangerous weaponry. A smart opponent will not let them live long so you need to make your initial volley count.
If you do go combi-melta rather than dual-infernus then I would at least give the serg melta bombs so that the diminished firepower is compensated for slightly by a more dangerous change in future turns (if they live that long).
1850 points
Commander Dante
Is Dante really bringing a lot to your list? Beyond being a beatstick, not much. Maybe think about dropping him entirely, or substantially rework the rest of your list to make him more worthwhile.
1x noviate
1x Champion
Mephiston
Not a fan of Mephi anymore. Would drop.
LVL 2 Librarian
Gallians Staff
Jump pack
Solid, but would add an Auspex and the Veritas Vitae and the Angel's Wing if you drop Dante.
Heavy flamer
Meltagun
Solid. The second infernus on the sarge could be dropped if you need the points, though it for use helps make sure tanks are dead dead.
Missile with flak
Would drop. The Sicaran can do the backfield babysitter job just as well in most cases. Replace with a cheapo 5-man CC Scout squad.
2 x Furioso in pod
Solid!
I'm not crazy about those, personaly. The amount of tanks that necessitate so much melta are fairly few and far between. Would invest in grav/MM bike squad instead.
Solid.
Comments in red. This is assuming you are going with the BSF. A CAD would need more Troops to make it worthwhile.
If your dealing with knights or other non rear av 10 veichles getting in to 3" melta range is not that reliable. I like the flexibility and value of 3 normal melta shots at a lower price.
If you want the same amount of anti-tank a multi-melta attack bike or a deepstriking 2x mm land speeder (they only scatter d6). Or perhaps finding a way to get 3 asault triple melta pods into the list.
I want to preface this by saying that I am a huge fan of the Sicaran. However, you might want to overthink that choice. A single tank, no matter how good, will get blown up. It will become a huge magnet for every AT gun on your table and the neighbouring one.
If you want infantry, go full on infantry.
Furioso dreads in your face turn 1 will hopefully prevent that, but I get your point
That's why it needs a DB - you'll want it out of LOS on turn 1 or at least obscured in ruins. Having just one is an advantage in this sense as you don't have vehicles grouping and competing for cover.
Fragioso was my fave unit in 6th ed, but nerf to magna grapple means its AT firepower is knocked by about 50%.
