Chefzilla Posted December 24, 2014 Share Posted December 24, 2014 Are these worth it? If so how's the best way to use them. Last night I had a game against the Tau and brought in my Vendetta on turn 3 with 6 scions. The twin linked lascannons tore up his riptide and crisis suits but then it was blown out of the sky at the beginning of the next turn. So here's a couple of questions. I know the scions have deep strike so if they're in a transport like the Vendetta does that get deep strike? Second, what's the best way to use this vehicle. I was thinking more as a gunship but if this not correct let me know. Link to comment https://bolterandchainsword.com/topic/300963-valkyrievendetta/ Share on other sites More sharing options...
CoffeeGrunt Posted December 24, 2014 Share Posted December 24, 2014 The Vendetta does great as Anti-Air and Anti-Tank, with a side of Transport ability. However against Tau you're facing easily-accessible anti-air and no Fliers. Against other opponents they're more potent, and if you're running a Company Command Squad it's worth considering an Officer of the Fleet to boost your Reserve Rolls to get it in earlier. It's an ideal weapon against Battlesuits as well. Link to comment https://bolterandchainsword.com/topic/300963-valkyrievendetta/#findComment-3899716 Share on other sites More sharing options...
Chefzilla Posted December 24, 2014 Author Share Posted December 24, 2014 Thanks Coffee. It's all about knowing your enemy. Link to comment https://bolterandchainsword.com/topic/300963-valkyrievendetta/#findComment-3899743 Share on other sites More sharing options...
Fibonacci Posted December 24, 2014 Share Posted December 24, 2014 . I know the scions have deep strike so if they're in a transport like the Vendetta does that get deep strike? Good idea, but no. Every model must have the deepstrike rule. It's the first line in te deepstrike rule if you want to see how the whole thing is worded. Link to comment https://bolterandchainsword.com/topic/300963-valkyrievendetta/#findComment-3899810 Share on other sites More sharing options...
WarriorFish Posted December 24, 2014 Share Posted December 24, 2014 Yes, Tau can muster anti-air tricks far easier than anyone else so they're not the best opponent. Otherwise they are worth it depending on what you need. I like to break it down as the Valkyrie being the transport that can be upgraded (missile pods) to be competent at handling infantry whereas the Vendetta is a gunship that happens to have room for 6 people :P Scions have a good deep strike ability, so arguably they don't really need a transport. A Vendetta will let you hunt enemy flyers well and pop tanks reliably, the ability to drop a small squad off to cause some mischief or sneak in to capture something is a very nice bonus. Also a good use for a PCS left hanging. Last but far from least its a cool model! As such you can't go far wrong with a Vendetta - versatility like that doesn't come cheap though but it is usually worth the expense. Link to comment https://bolterandchainsword.com/topic/300963-valkyrievendetta/#findComment-3900065 Share on other sites More sharing options...
scatmandoo Posted December 25, 2014 Share Posted December 25, 2014 As the Fish has said. Vendetta is primarily a heavy hitter that is best used carrying a CCS/PCS/SWS as a back up to it's firepower. The Valkyrie is best seen as a really fast Chimera that has a primary use of dropping whatever unit you place in it to where you want. The anti-infantry function should be seen as secondary. Link to comment https://bolterandchainsword.com/topic/300963-valkyrievendetta/#findComment-3900230 Share on other sites More sharing options...
Frater Cornelius Posted December 25, 2014 Share Posted December 25, 2014 Vultures, baby. That's where it's at ;) Link to comment https://bolterandchainsword.com/topic/300963-valkyrievendetta/#findComment-3900400 Share on other sites More sharing options...
