New Dreadnaught coming
Fire Golem
So do you think that means they will be rapid firing auto cannons then? Like the predator?
8 twin linked auto cannon shots (at I presume BS5) is still nothing to sniff at.
I wouldn't put it out of the realm of possibility.  I mean, its got those huge ammo feeds and hoppers compared to the fairly small magazines on the Contemptor.  That says, to me, we might see some kind of rate of fire increase.  Either way, rifleman dreadnoughts are a thing anyway, I wouldn't be too put out if they're just standard autocannons.
So long as the points cost reflects that.
That would make it on par with a land raider though, correct?
I feel the same in that it should be a teeny bit tougher than a normal contemptor, but 4hp seems a bit much.
If only there was a way to give it 3.5 hull points...
Perhaps it's just a sensor suite containing the anti-air stuff, and doesn't actually result in increased armour, similar to how a nose cone containing radar kit on aircraft doesn't make armour any more protected? It could be that which represents it gaining Interceptor, for example, as a rule.
Crosspost from News:
http://i.imgur.com/7V2RLA6.jpg
I did a quick comparison with the contemptor, using the base size as the common reference point.  The size difference between them is quite small, the Deredeo sure counts as 'largest,' but not by much.  This won't be a superheavy as some of you have hoped or anything close to it.  I also think those are regular autocannons on the arms - you can see how similar they are to the ones on the standard contemptor.  The sicaran barrels are thicker and have more cowling on them, so I think we can safely put the rumor/hope that they're accelerator autocannons to bed.
Yeah, that's what I thought originally. However, when you look at the autocannons' muzzles, there are three indentations at the end, rather than the normal four, as seen on the contemptor next to it. The only autocannons we've seen that have the same muzzles are the Sicaran's accelerator autocannons - there's also a slight disparity between these autocannons'  barrel length & width and the contemptor's too - okay the accelerator autocannons on the Sicaran have more cowling & a larger body, but that might be as much to do with their mounts on the turret & the ammunition system than anything else.
Obviously we can't yet say for certain one way or the other, it's just that the from the base of the barrel onwards, they're basically identical to the Sicaran's autocannons. Personally, I'd prefer it if these were normal autocannons (OP much?) but for those of you frothing at the mouth for the idea of 2 twin-linked accelerator autocannons, don't loose hope just yet.
Good break down. For me the strongest evidence for those cannons being accelerator autocannons is the belt-fed ammunition.
I really don't think they're sicaran accelerator cannons. They look nothing like them. In fact they look exactly like normal autocannons. That doesn't entirely seem to fit though with the longer barrels and huge ammo feeders, so I'm putting my money on them being like predator autocannons, which are heavy 4. Accelerator cannons would just be too much though
Maybe a Reaper Autocannon Battery (as in the Fire Raptor one)? Although the 3 tiered muzzle brake is different from the four tiered. However, the similarity between the Autocannons is that
Also, it's got quite a weight to pull behind the Mortis - S7 isn't exactly that much better than S6 Rending due to Rending's ability to hit AV14 targets and take down SH flyers like Thunderhawks, and the rumoured Warhawk Pattern Stormbird (there are two patterns of Stormbird mentioned in Conquest - the smaller Warhawk and the heavy Condor pattern).
Kit... Can you photoshop a contemptor torso on there???
Sure.
http://i.imgur.com/mRu93Ub.jpg
I think that's one you'd have to puzzle out a little more with the pieces in hand.  The heavy flamers/heavy bolters are the torso would need some kind of accommodation made for them, and you might have to put together some new, thicker lower-abdomen section to get it to mate up right with the hips.
I like the box look more.  You can probably fab that up with some plasticard instead of having to butcher two dreadnoughts for it, and the boxy dreadnoughts have always needed more leg to them to make them look properly proportionate.
