daemon base size, 32mm?
What daemons do we expect to go to 32mm if any?
I am finishing my khorne army and want to get a census. Should/could bloodletters be on 32mm?
My marines will be 32mm, so I can go either way. I like the idea of them staying on 25mm so they look less impressive than my beserkers, but fluff/size wise should I put them on bigger?
Same question for other lesser daemons.
https://bolterandchainsword.com/topic/301218-daemon-base-size-32mm/
I doubt anyone will be hugely bothered and GW don't release any hard and fast basing rules so base away on the size you like. 32mm if you like that little extra basing space and stability or 25mm if you've already used loads that size and like the look.
No, use the base that the model is supplied with as a default.
This rule has been in the book since 3rd edition, no reason to think this will ever change. So my mate whom plays RT nids that were are supplied with square bases is as relevant now as it was when he first bought them
  • 4 weeks later...
  • 3 weeks later...
Having seen smaller-than-astartes minis on the new 32mm bases, I'm definitely thinking of getting some for my daemons. I've always liked to put display minis on 40mm bases with a load of scenic Stuff, and that's basically the effect you get when you put anything smaller than a space marine on the new bases. It's fantastic.
Flamers would probably benefit from the larger base, both in looks and stablity.
Haha yeah. Mine are metal, and they Do Not Stay Upright Well. Pinning them to 32mm bases should fix that, hopefully. I don't have any of the plastic ones, but they seem pretty sizeable, so they'd also probably do well on these.
  • 1 month later...
