Uprising Posted December 31, 2014 Share Posted December 31, 2014 I am wondering if anyone knows a good source for cheap 28mm barb wire for bases? Link to comment https://bolterandchainsword.com/topic/301228-barb-wire/ Share on other sites More sharing options...
Kriegsmacht Posted December 31, 2014 Share Posted December 31, 2014 Army Painter sells a blister pack of Razorwire for 5.00 US. You get 2.5 meter length and can be used for 28mm. Link to comment https://bolterandchainsword.com/topic/301228-barb-wire/#findComment-3904999 Share on other sites More sharing options...
Gorkimedes Posted December 31, 2014 Share Posted December 31, 2014 Don't know about buying it but this is a tutorial I've looked at before. http://www.dakkadakka.com/dakkaforum/posts/list/314348.page Link to comment https://bolterandchainsword.com/topic/301228-barb-wire/#findComment-3905039 Share on other sites More sharing options...
Uprising Posted January 1, 2015 Author Share Posted January 1, 2015 Thank you both Link to comment https://bolterandchainsword.com/topic/301228-barb-wire/#findComment-3906564 Share on other sites More sharing options...
Space Truckin Posted January 1, 2015 Share Posted January 1, 2015 Don't know about buying it but this is a tutorial I've looked at before. http://www.dakkadakka.com/dakkaforum/posts/list/314348.page Great tutorial! Thanks a ton! Link to comment https://bolterandchainsword.com/topic/301228-barb-wire/#findComment-3906571 Share on other sites More sharing options...
Chaeron Posted January 2, 2015 Share Posted January 2, 2015 I use Army Painter - bright but cost effective! Link to comment https://bolterandchainsword.com/topic/301228-barb-wire/#findComment-3906936 Share on other sites More sharing options...
awilden Posted January 4, 2015 Share Posted January 4, 2015 Don't know about buying it but this is a tutorial I've looked at before. http://www.dakkadakka.com/dakkaforum/posts/list/314348.page Oh wow that looks awesome, I can however see myself going mad trying to do it, looks incredibly fiddly, the Secret Weapon razor wire pack is pretty good, haven't had a chance to use mine yet, but its very cool looking, although that's really razor wire and not barbed wire, not fond of the GW barbed wire kit (there are other similar ones too), basically wire wrapped around wire, it does the job, but you look even reasonably closely and you can tell its not barbed wire. I did have a go at making my own from mesh before (mesh that's basically horizontal wire interlaced with vertical wire), it's hard to explain, but if you cut it in strips horizontally or vertically, technically you can super glue the strands together and then when you cut it small enough it becomes one long string of wire, with lots of little pieces intersecting (if you don't glue them though they all just fall off). Link to comment https://bolterandchainsword.com/topic/301228-barb-wire/#findComment-3908923 Share on other sites More sharing options...
