Interceptor and units disembarking from a vehicle...
Ishagu
Interceptor may be used against any unit that arrived from Reserve, it doesn't matter how they arrived. Nothing in the rule mentions order of arrival.
This - at the end of the enemy movement phase pick one unit that has entered from reserves, and is in range and line of sight.
EDIT -  Ninja'd!
A few have argued that the unit inside isn't coming from reserve, but is coming from inside the pod...
I argued that the pod and the unit inside are coming from reserve, which is certainly the case.
The whole thing was dumb, but part of me was hoping some of it could be true.
Nothing would make me happier than having a deepstrike that Tau can't deal with so easily...
I only ever run a single pod, with a combat squadded Sternguard unit or a command squad inside. I've never used it against a Tau list in fear of their Interceptor so the issue hasn't really come up in my games...
Point them to the Combined Reserve Units section of the Reserves rule.
"you must specify if any units in Reserve are embarked upon any Transport vehicles in Reserve, in which case they will arrive together"
They both arrive from reserves.
Yep. The unit can be intercepted..
In my opinion that's stupid, intercepting something should be exactly that, INTERCEPTING!!! , I.e shooting at the pod on its way down... Not waiting for it to land... then wait a few for the doors to blow..... then wait a few more for them to gather their bearings/surrounding.... and then leave.
And then how do you represent the unit managing to intercept said drop pod? By destroying the pod and having all occupants miraculously survive the crash?
Would be the same as a vehicle explodes result from the damage table? Wold be stupid to have the pod intercepted and killed, to have the guys completely unscathed..
That's IF the pod was even destroyed, could just take a hull point off and protect the squad like it's supposed to.
That's usually indicated by the Reserve Roll failing to deliver. Currently, Interceptor is activatable only at the end of the Movement Phase, not in the middle.
  • 2 weeks later...
No it says they are embarked on the transport that arrives from reserves it's still a separate uint. Once disembarked acts separately, if you rolled for the transport and the uint you wished to embark in the transport to successfully arrive from reserve I could understand your argument but it's only the transport that actually arrives from reserves the uint is just piggy backing? If that makes sense but this is just how I am interepting it.
So, you are saying that a unit put in Reserves and then leaves Reserves and enters the table ISN'T coming in from Reserves because it took a taxi?
That would be same if you said that Assault Marines coming in from reserves don't arrive from reserves, it's their jump packs arriving and the Marines are just 'piggy backing'.
No I only mentioned transports not infantry like jump uints or things like terminators. Which don't appear on the board in anything before they themselves are on the table.
Please don't stretch the meaning of my words, it's merely an opinion as the words GW used are so vague I think work it out with your opponent before you start the game.
Kristoff:- I suppose so.. Don't really get what you mean by leave and come back?
You start the game either on the table or in Reserves, and that's ironclad. So, if the transported models are off the table, they're in Reserves. They can't be put into Reserves, magically removed from the game, then magically appear on the table.
In order to be put on the table after the game begins, a unit needs to be in Reserves. In order to then enter the table, it must leave Reserves. At which point, it then "comes in from Reserves".
What you were saying is that because they rode something they never came from the place they just left.
If I take an airplane from Phoenix to New york, did I just arrive from Phoenix or from an airplane?
The answer is "both". Being on an airplane doesn't preclude me from not coming from Phoenix, if anything, it's the method whereby I traveled between Phoenix and New York.
So, when a unit rides a Transport when it appears on the table after the game begins, it is STILL coming from Reserves just as much as if it walked on.
The section "Combined Reserve Units" on page 135 is pertinent to this.  Namely "You must specify if any units in Reserve are embarked upon any Transport vehicles in reserve, in which case they will arrive together"
Therefore, when any embarked unit arrives from reserve in their transport they have still "arrived from reserves" that turn as they "arrive together".
