Contemptor Loadout Dilemma - I can't believe it has happened
Slips
As the Title says, I have a dilemma with giving my IF Contemptor a Loadout.
-I already have 2 Morits' : Autocannon and Lascannons (which I prefer over the Kheres just because of the Range, not that I'm against the weapon)
-A Dual DCCW Dread that I used for the Alpha Legion March
-And a yet-unpainted Relic Contemptor that has a DCCW and TLHB (The HB I most likely will change - maybe in the same order that I get the IF dread and its Arms in).
So yeah, I've got 4 Contemptors and I'm getting a 5th and don't know how to gear it out.
A bit more info on why I have Trouble giving it a loadout is because I want to keep it as a more Fluffy > Competitive and not have any repeat Loadouts. While I could Magnetize the arms and save myself some cash, its not really my thing because reasons.
Now, Taking into account the Relic Contemptor that I may take the TLHB off at some point, I have two Dreads to work with. I could slap a Heavy Conversion beamer and DCCW on the Relic and do something else on the Imperial Fists Dread; since I don't see it, in my minds eye, as a Backfield Fire-Support Dreadnought. Mostly because of the First Company Heraldry present upon the chassis.
I'm also greatly saddened that FW haven't released a Volkite Culverin Dreadnought Arm yet (unless I'm blind and haven't seen it on FW site).
So, what do you all suggest I do with my one/two Dread(s)? Am I not thinking outside the box enough? :p
I love the assault cannon too, but yeah. Conversion Beamer and Plasma Cannon feel different to what you already have, if you get me. Maybe Plasma Cannon and CCW, seeing as you don't want it backfield? I agree they should do a Volkite dread weapon though.
While coolawsomegreat I don't think Contemptors can have Dual Heavy Conversion Beamers. sad.png
May just go with the Relic Having the Beamer and the Legion having a Plasma Cannon and Chainfist; which I just may make using the Chain Bayonets and a Standard Power Fist. Titan Style Chain-Fingers.
That's how I'd make my chainfists :)
Volkites are an option too. Do it for the lasers.
But laziness + no current Forgeworld model = not going to happen. I'd rather not have to buy 5 Culverins and Cannibalize 1 or 2 of them to make a Contemptor Weapon :x
Or hack apart a Leman Russ' Demi-Culverin. An option that is by no means cheap to accomplish.
@_@ I want more Volkites but FW ain't, as Judas Priest would say, Delivering the Goods.
Yes, Contemptors can take volkite culverins. Not bad choice given the range and deflagrate rule. No iteration of Contemptor rules anywhere allows dual conversion beamers, however. Changing the TL HB to a conversion beamer isn't a bad choice, given that the former weapon is pretty lackluster for such an expensive unit (looks totally sweet though). You already have a good mix of options, but perhaps mostly geared for long range engagements except for the close combat specialist. If you intend to utilize your new contemptor as a more medium to close range unit, then perhaps you should give the Kheres another look. Supplement it with some a DCCW with either melta or a heavy flamer. There's also multimelta to consider if you want it to be able to take down vehicles at close range.
EDIT: Culverin option for contemptors are in the crusade army list book, which is pretty much an errata. It was indeed not in betrayal.
Don't worry, I try to do it by suggesting Iron Man Style Volkites-in-Power-Fists in some WIP threads in the Forge :p
Sadly, Twin Plasma Cannons feels more Dark Angels than it does Imperial Fists. The more I think about it, the more I feel that the Kheres is the fluffiest option, besides the TLHB but, lets be honest, its pretty lame by comparison.
That or a Volkite Culverin. :Cuss Yeah! Volkites!
Volkite Serpenta : Pistol
Volkite Charger : 15" Assault 2 (think SMG)
Volkite Caliver : 30" Heavy 1 (think Assault Rifle)
Volkite Culverin : 45" Heavy 4
Volkite Demi-Culverin : 45" tank weapon - dont remember rules.
Volkite Chieroville (or however you spell it) : 45" Heavy 5 (its on a Knight)
Volkite Carronade : 48" of :cuss you
If the new Dreadnought can have Demi-Culverins / Chierovilles OR MAYBE A CARRONADE :OOOOOOO I'd be all over that like Snow in Canada : way too :cuss ing much.
But yeah, back on topic and not drooling about Volkites (should that be its own thread at this point?), Kheres, Conversion Beamer and Plasma Cannon look to all be purchases along with the FW Chainfist (I'll fix it or die suddenly start finding it less horrific).
I'm not convinced about ever giving a Contemptor a Multi-Melta unless your up against Non-Armored Ceramite units or playing 40k.
I also wish that, on a Dreadnought, the Heavy Bolter would be better. Maybe if it was a Quad Heavy Bolter... Or got the Imperial Fists +1BS rule. Something like that...
Looks like I'm getting closer and closer to being able to field a Dreadnought List. Will soon have 5 Contemptors (2 Mortis' ARGH MY ELITES SLOTS) and 4 Box dreads (2 Ironclads, 1 Chaplain and 1 Bog-Standard). Couple that with the Teaser we've just got (PLEASE BE HEAVY SUPPORT MY POOR ELITES SLOT)...
Had a little chat with Wolf_Pack about the loadout and well, he made me aware of the Seismic Hammer for Ironclad Dreads http://www.forgeworld.co.uk/Warhammer-40000/Space_Marines/Space-Marine-Dreadnoughts/MKIV_IRONCLAD_SEISMIC_HAMMER.html and its just my luck that the connecting joint to the shoulder is the same as the ones on Contemptor Arms. So I might use that en lieu of a DCCW or Chain Fist.
Also thought about giving it an Flamestorm / Inferno Cannon but I think my laziness/ineptitude will limit the possibility of this becoming a reality despite how awesome it would look.
Will probably stick with the Kheres for the other arm.
