xxoblivionxx33 Posted January 9, 2015 Share Posted January 9, 2015 Hey guys , so i've decided I'm going to do night lords. I have all sorts of bits and the forge world pads and heads on order. I need an opinion on obliterators though. The common trend for NL seems to be 2 dudes with special weapons on a 40mm base. I do like this, but i was curious as to if anyone had any different versions of it(that stray away from the standard flesh metal obliterator) Link to comment Share on other sites More sharing options...
Jolemai Posted January 9, 2015 Share Posted January 9, 2015 For what it's worth, a friend of mine uses Thallax Cohorts as his. Link to comment Share on other sites More sharing options...
Dragonlover Posted January 9, 2015 Share Posted January 9, 2015 I always liked the idea of the Mechanicus Secutors from Forge World. Dragonlover Link to comment Share on other sites More sharing options...
Rasclomalum Posted January 9, 2015 Share Posted January 9, 2015 Oh, there certainly are viable alternatives. You could always use terminators as a base and go from there. If that doesn't strike your fancy, I once saw a great Obliterator conversion using the new plastic Ogryn, so you could try that. Or chaosify some centurions. Link to comment Share on other sites More sharing options...
xxoblivionxx33 Posted January 9, 2015 Author Share Posted January 9, 2015 i was thinking of the centurion route, but centurions seem counter productive to what a night lords tactical doctrine would be. Link to comment Share on other sites More sharing options...
God-Potato of Mankind Posted January 9, 2015 Share Posted January 9, 2015 So do Obliterators really, but ultimately they're Astartes they will use everything. I second Secutors. I have a trio and they are truly imposing, sinister models. They could be easily evilled up as they already look so creepy. Plus their axes are taller than a Legionary. Nngggh. Link to comment Share on other sites More sharing options...
Chaeron Posted January 9, 2015 Share Posted January 9, 2015 HiTech Terrorizers are popular - worth a consideration, but they're again in the Obliterator mould. Link to comment Share on other sites More sharing options...
xxoblivionxx33 Posted January 9, 2015 Author Share Posted January 9, 2015 anybody know of any companies that make night lords-esque bits? i'll check out the hitech line / Correct me if I'm wrong, but the concept between the 2 dudes on the base for an obliterator is that the Night Lords use strike teams? Link to comment Share on other sites More sharing options...
