Chefzilla Posted January 11, 2015 Share Posted January 11, 2015 Is the Executioner Plasma cannon worth using? The 3 dice at Ap 2 sounds fantastic but the thought of my tank vaporizing tweeks me out. Link to comment https://bolterandchainsword.com/topic/301849-demolisher-leman-russ-users/ Share on other sites More sharing options...
scatmandoo Posted January 11, 2015 Share Posted January 11, 2015 I use it with Plasma sponson's too. Maybe a sucker for punishment, but in 20 or so games it has only killed itself once in a single shooting phase with some appalling dice. The rest of the time, it loses the odd hull point but normally I can save it on the 4+ you get. Worth the risk for the threat and damage output in my book eapecially when joined by another or Plasma sentinels as wing men. Link to comment https://bolterandchainsword.com/topic/301849-demolisher-leman-russ-users/#findComment-3917098 Share on other sites More sharing options...
WarriorFish Posted January 12, 2015 Share Posted January 12, 2015 I was confused for a moment, I thought the topic title simply said "Everyone"... :P The Executioner is good, if can be even better if you want to spend some points on it but it is a specialist Russ so you should only take it if you need it. For example if tough MCs or super heavy infantry are regular opponents then it could be a great addition. As scats said there is the risk of overheating (a change to the vehicles rules I disagree with). It's not a huge risk but enough that you should take it into consideration, for example I think the main gun is enough so don't take plasma cannon sponsons. Of course for modelling concerns you simple take all three options for the tank as it is very easy to magnetise ;) Link to comment https://bolterandchainsword.com/topic/301849-demolisher-leman-russ-users/#findComment-3917862 Share on other sites More sharing options...
