So whose doing Solar Auxilia?
Emperor's Furor
I'm using Dreamforges' Valkir Heavy infantry... when it's released, that is.
http://cdn.shopify.com/s/files/1/0284/7086/products/1_large.jpg?v=1411110844
I prefer autoguns over las-weapons, plus I'm really digging the heavy carapace look on these dudes. Might swap the heads though...
I'm doing SA
Currently built, 20 las riflemen, 20 storm fellas, 10 flamer dude, and an Incinerator. Got another 20 las riflemen to build.
Next month I'm planning on adding some Dracosan's, some more Russ's, and maybe some bombards.
Oh and making some axe wielding Household troops out of either Vostroyans, which seems like hard work, or Scions, which seems easier.
Not exactly miniatures, but I'm tentatively considering using FW images (including the SA ones in Conquest) to construct some designs for Medusan Clanguard & 'Chainveil' Auxiliaries
However, if they don't meet the same resolution / quality of the FW images they'll inevitably be purged from my hard drive
Between my RG, Mechanicum, Knight House, and Titan Legion my hands are full. Wallet is empty.
When you see some new releases from FW and then check your bank balance...
http://i.imgur.com/G1YQxhu.gif
I wish I was doing these bad ass space crusaders. Between my RG, Mechanicum, Knight House, and Titan Legion my hands are full. Wallet is empty.
I'm putting my SA first, Mechanicum second and AL is just a kill team at the mo.
Your work is easily up there with any model based log.
Hmmm - if they were your lasrifle sections, you could convert the Valkir Assault Troopers to Veletaris with power axes & the Support versions to Flamer sections. Then of course you've got the upcoming command units too.
Although Lucifer Blacks ain't exactly the penal legions normally consigned to work alongside the IVth, I guess sometimes you must get some decent support tongue.png
Also, the Cadian respirator heads from FW might work - plus you get loads of kit with them
Then again, pretty much any maxmini heads would work - the space police, tox guarsman & biohazard ones particularly. Although not particularly sci-fy, the gladiator helms might give a cool vibe.
