Shaezus Posted January 14, 2015 Share Posted January 14, 2015 Example situation: An IG blob in open ground but behind an aegis, with a commisar in the middle. BA Libby casts Blood Boil and shoots from the other side of the aegis at the commisar, who fails a T test. The rules say no saves of any kind allowed, does this include look out sir? From the resulting large blast, do the surrounding guardsmen gain cover because the original shot was fired over the aegis? My answer to both would be no, but I cannot access my BRB on my phone and am curious what people think. If he could LoS it then there would be no large blast, as the targeted model must die. Only asking because you know what some people are like. Link to comment Share on other sites More sharing options...
Ushtarador Posted January 14, 2015 Share Posted January 14, 2015 Agree with the second question, the blast originates from the exploding model, so there should be no cover. No idea about the first one though.. and that doesn't happen often oO Link to comment Share on other sites More sharing options...
tylerw Posted January 14, 2015 Share Posted January 14, 2015 Agree with the second question, the blast originates from the exploding model, so there should be no cover. No idea about the first one though.. and that doesn't happen often oO I thought cover for blasts was still determined by whether you have LOS to each individual model. Barrage cover LOS is from the center of the target, as I understand it, but isn't blast still LOS to/from the shooter? Link to comment Share on other sites More sharing options...
gustmic Posted January 14, 2015 Share Posted January 14, 2015 On the first question, I'd say since it is of a (focussed) witchfire type, it is handled as a shooting attack. Thus, I would think that a LoS roll would apply here. It is analog to the 6th "focused fire" special rule, I would assume. Note that LoS-roll is not a save. On the second point, it says in the text of "Blood Boil" that it ignores cover. However, other saves are ok. RAI I would handle it as a barrage, but RAW I am not sure. /gustmic Link to comment Share on other sites More sharing options...
SnorriSnorrison Posted January 14, 2015 Share Posted January 14, 2015 I'd target any of the sergeants that are available in such a blob. As gustmic said, the blast itself ignores cover and also has AP5, so the guardsmen would die after the first failed toughness test of said sergeant. As pointed out, it's a shooting attack, so LoS applies here - but doesn't really matter unless that targeted model stands next to a multi-wound model. Other than saving a special (melee) weapon of some sort, taking a LoS test for the sergeant doesn't really make sense, because the next guardsmen will die just as easily. Once the wound is taken, BOOM and a huge hole in that blob is all what remains. That power does sound very cool. Also nice for dug-in pathfinders/anything that relies on a coversave with low toughness value. Snorri Link to comment Share on other sites More sharing options...
Xenith Posted January 14, 2015 Share Posted January 14, 2015 Example situation: An IG blob in open ground but behind an aegis, with a commisar in the middle. BA Libby casts Blood Boil and shoots from the other side of the aegis at the commisar, who fails a T test. The rules say no saves of any kind allowed, does this include look out sir? From the resulting large blast, do the surrounding guardsmen gain cover because the original shot was fired over the aegis? My answer to both would be no, but I cannot access my BRB on my phone and am curious what people think. If he could LoS it then there would be no large blast, as the targeted model must die. Only asking because you know what some people are like. Saves are made after wounds are allocated to models. Look out sir is not a save, it is a roll to see if the wound that you have allocated can be re-allocated by the defending player. If you allocate a wound to a model, then it always gets to look out sir, unless there is a special rule which states otherwise. Link to comment Share on other sites More sharing options...
Shaezus Posted January 14, 2015 Author Share Posted January 14, 2015 Thanks ever so much for the replies fellas. You all do credit to the forum :) The safest bet in the above example would be to use on a non-character model, this way LoS can't prevent the blast kicking off. Cheers. Link to comment Share on other sites More sharing options...
Xenith Posted January 14, 2015 Share Posted January 14, 2015 Well, I'd do it on a (non independent) character anyway. Even if they pass a look out sir, the end result is the same as your option, the wound being allocated to a non character. I guess you could selectively target models at the back so your bolters are still in RF range or you're in assault range etc. Link to comment Share on other sites More sharing options...
Shaezus Posted January 14, 2015 Author Share Posted January 14, 2015 The only reason I'm thinking of targeting a non-character is that the rules for BB say that 'if they (the target) are slain, centre the large blast marker..'; RAI the blast would still be placed if a model other than the target takes the wound(s), but RAW this could be interpreted otherwise. Not that I would say anything unless my oppo interrupts me when placing the marker. Plenty of rules bandits around so I'm just playing naysayer to myself really. Link to comment Share on other sites More sharing options...
Arkangilos Posted January 14, 2015 Share Posted January 14, 2015 I understand it may be in the rules, but that doesn't make any sense at all. How can someone say, "Look out sir!" and jump in the way of your internal organs and blood boiling? That's basically like a Librarian waiving his hand, your blood boiling, and someone else, who has a totally different set of insides, pushing you out of the way to be boiled instead... I just don't get it. Link to comment Share on other sites More sharing options...
Shaezus Posted January 14, 2015 Author Share Posted January 14, 2015 Totally agree! Link to comment Share on other sites More sharing options...
Arkangilos Posted January 14, 2015 Share Posted January 14, 2015 Totally agree! Well if we play, we won't use the LoS rule then, lol. Link to comment Share on other sites More sharing options...
Xenith Posted January 15, 2015 Share Posted January 15, 2015 I understand it may be in the rules, but that doesn't make any sense at all. How can someone say, "Look out sir!" and jump in the way of your internal organs and blood boiling? That's basically like a Librarian waiving his hand, your blood boiling, and someone else, who has a totally different set of insides, pushing you out of the way to be boiled instead... I just don't get it. The quote in the rulebook is that the new model breaks the direct link needed between the psyker and target (deadly mind lock) and thus becomes the new target. Same thing with cover Link to comment Share on other sites More sharing options...
