CarbonBased Posted June 24, 2015 Share Posted June 24, 2015 I really really wish I was still working in rapid prototyping. So many models I could be printing in the open spaces of production builds... Link to comment https://bolterandchainsword.com/topic/302174-big-3d-print-post-whirlwind-scorpius-major-update/page/2/#findComment-4100880 Share on other sites More sharing options...
twopounder Posted August 13, 2015 Author Share Posted August 13, 2015 I really really wish I was still working in rapid prototyping. So many models I could be printing in the open spaces of production builds... Well, you can still use companies like Shapeways. It's not free but they have a myriad of different materials to pick from. They just added another level of detailed plastic (frosted extreme detail) that should make for some epically good models. It's $5.99 per cm3 though, so not cheap. Link to comment https://bolterandchainsword.com/topic/302174-big-3d-print-post-whirlwind-scorpius-major-update/page/2/#findComment-4145396 Share on other sites More sharing options...
HardCoil Posted August 13, 2015 Share Posted August 13, 2015 Extreme detail is really nice, but there's still obvious print lines if you have flat areas and are unlcuky with the alignment. Link to comment https://bolterandchainsword.com/topic/302174-big-3d-print-post-whirlwind-scorpius-major-update/page/2/#findComment-4145774 Share on other sites More sharing options...
twopounder Posted August 14, 2015 Author Share Posted August 14, 2015 Extreme detail is really nice, but there's still obvious print lines if you have flat areas and are unlcuky with the alignment. Yeah, I've considered getting a tumbler to do some polishing. My issue is mostly that printing 10 - 20 models is prohibitively expensive. I have almost everything I need to do casting, just need a vacuum pump for my degassing chamber and I can resin cast my 3d prints. Link to comment https://bolterandchainsword.com/topic/302174-big-3d-print-post-whirlwind-scorpius-major-update/page/2/#findComment-4146400 Share on other sites More sharing options...
HardCoil Posted August 14, 2015 Share Posted August 14, 2015 I don't think a tumbler would be a good idea at this detail level, you'll lose all that detail you pay for. My prints could be cleaned up pretty quickly with a flexifile, as the lines were only noticable on flat areas perpendicular to the print direction. My long term plan is to just clean them manually and cast :) Link to comment https://bolterandchainsword.com/topic/302174-big-3d-print-post-whirlwind-scorpius-major-update/page/2/#findComment-4146734 Share on other sites More sharing options...
Kronus Stormbringer Posted August 15, 2015 Share Posted August 15, 2015 Some fantastic design work here, much better then the standard template stuff all marine chapters share Link to comment https://bolterandchainsword.com/topic/302174-big-3d-print-post-whirlwind-scorpius-major-update/page/2/#findComment-4147316 Share on other sites More sharing options...
twopounder Posted November 3, 2015 Author Share Posted November 3, 2015 I don't think a tumbler would be a good idea at this detail level, you'll lose all that detail you pay for. My prints could be cleaned up pretty quickly with a flexifile, as the lines were only noticable on flat areas perpendicular to the print direction. My long term plan is to just clean them manually and cast That can take a lot of time for a full clean, and the smaller areas can be especially difficult. Though the medium is getting better and better. May not need any cleanup work in a few years,. Some fantastic design work here, much better then the standard template stuff all marine chapters share Thanks. I actually wanted to make a more Dark Angel oriented design as well. It takes a lot of time to get themes correctly, and some are hit and miss. It's a fine balance between flavor and ridiculous. Link to comment https://bolterandchainsword.com/topic/302174-big-3d-print-post-whirlwind-scorpius-major-update/page/2/#findComment-4214596 Share on other sites More sharing options...
