appiah4 Posted January 19, 2015 Share Posted January 19, 2015 Without going into details that would open a can of worms, I need to replace a badly cracked/bent sword on my Space Hulk Sergeant Lorenzo. I was wondering if the sword used on the sculpt was reused as a bit elsewhere. The replacement ideas I currently have are: Company Champion Power Sword (Mainly because the size looks similar, but the shape is eh..) http://www.bitsandkits.co.uk/images/SM12.JPG Chaos Warrior Command Sword (Obviously need to de-Chaosify and fill the nicks etc.) http://www.bitsandkits.co.uk/images/230609273862.jpg Chaos Forsaken Sword (After de-Chaosification) http://www.bitsandkits.co.uk/images/34-forsaken%20(29).JPG Dark Elf Executioner sword (Shape is great but not sure about size at all) http://www.bitsandkits.co.uk/images/blackguard%20(5).JPG Your suggestion would be which of the above? Or if none, what would you use? Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/ Share on other sites More sharing options...
Lucien Eilam Posted January 19, 2015 Share Posted January 19, 2015 Mephiston's sword is a fairly close match. You could probably buy a whole new Lorenzo for the price of Mephiston new, but if you keep an eye on eBay, a badly painted example you could strip will probably turn up for a couple of quid sooner or later. Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/#findComment-3925629 Share on other sites More sharing options...
Xenith Posted January 19, 2015 Share Posted January 19, 2015 How bad is the break? one of the side spindels on my friends broke, and I resculpted it with GS. You should generally able to pin it. Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/#findComment-3925630 Share on other sites More sharing options...
appiah4 Posted January 19, 2015 Author Share Posted January 19, 2015 It actually didn't completely break, what happened was that the blade got bent backwards until it sort of cracked at where it meets the hilt. Hypothetically, I could warm it, bend it back in place and use milliput to cover the crack. With my luck, I'll end up completely snapping it off. So erring on the side of caution, I'm looking for a replacement anyway. I also realized that the Mephiston Sword is a VERY similar copy, unfortunately that figure is stupidly expensive for being so stupidly old and ugly (20 years old now..). And I would really feel bad about hacking off bitz from figures that belong on collections and displays anyhow :) So I'm currently leaning towards the Chaos Warrior Command Sword.. Looks pretty much the same size and shape.. I wonder if there's a way I can learn the exact length of the blade on this bit, so I can compare.. http://www.bitsandkits.co.uk/images/230609273862.jpg Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/#findComment-3925655 Share on other sites More sharing options...
Lucien Eilam Posted January 19, 2015 Share Posted January 19, 2015 I have a few of those lying around, I'll take a comparison photo tonight if nobody's done it before then. Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/#findComment-3925661 Share on other sites More sharing options...
appiah4 Posted January 19, 2015 Author Share Posted January 19, 2015 I have a few of those lying around, I'll take a comparison photo tonight if nobody's done it before then. That would be terrific, thank you very much. Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/#findComment-3925669 Share on other sites More sharing options...
Lucien Eilam Posted January 19, 2015 Share Posted January 19, 2015 That would be terrific, thank you very much. Here you go mate. Pretty close match in size: http://cdn.lightbringers-space-marines.net/wip/swords.jpg Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/#findComment-3926137 Share on other sites More sharing options...
appiah4 Posted January 20, 2015 Author Share Posted January 20, 2015 That would be terrific, thank you very much. Here you go mate. Pretty close match in size: http://cdn.lightbringers-space-marines.net/wip/swords.jpg Perfect my friend thank you very much. I just ordered one. Link to comment https://bolterandchainsword.com/topic/302265-replacing-sergeant-lorenzos-power-sword/#findComment-3926351 Share on other sites More sharing options...
