Charlo Posted January 19, 2015 Share Posted January 19, 2015 Evening Brothers, I recently got a Pin Vice from amazon with some drill bits and I'm a little confused. I managed (with some substantial effort) to drill some small holes (like a gun barrel as a test) but it seems that often the thing will get caught in the plastic and just stop spinning/ drlling Is there are way to alleviate this? I've also noticed that the drill bits aren't held in place by the thing... At all, even the biggest one I have just falls out when it is tightened fully? Am I doing anything wrong?! Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/ Share on other sites More sharing options...
Brother-Chaplain Kage Posted January 19, 2015 Share Posted January 19, 2015 The problem with the drill bit stopping like you described is either it's not secured tightly enough in the chuck, or there's too much waste material in the drilled hole. I've had the second problem happen with some extremely cheap drill bits I bought at a dollar store because some of they were smaller diameter than I could normally find, and they just didn't clear out the debris like the higher quality bits did. For the problem of them not being secured enough or falling out as you describe, can you post a picture of what you bought? It might help ID the problem. Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3925966 Share on other sites More sharing options...
Charlo Posted January 19, 2015 Author Share Posted January 19, 2015 I got this from amazon: http://www.amazon.co.uk/gp/product/B00K7ZV86I?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 And here is a pic of the chucks. Maybe I have to use the thin end to hold the bit in place? But i would have to literally pry it open to let me get it in there? http://i1380.photobucket.com/albums/ah177/nevscorner/20150119_195816_zpsjlerpmms.jpghttp://i1380.photobucket.com/albums/ah177/nevscorner/20150119_200220_zpsc70u765r.jpg Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3925983 Share on other sites More sharing options...
Brother-Chaplain Kage Posted January 19, 2015 Share Posted January 19, 2015 There should be another chuck(or collet) inside the handle with other sizes. Unscrew the back end. Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3926016 Share on other sites More sharing options...
Charlo Posted January 19, 2015 Author Share Posted January 19, 2015 I did already and it's seemingly exactly the same Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3926032 Share on other sites More sharing options...
Brother-Chaplain Kage Posted January 19, 2015 Share Posted January 19, 2015 The one I have like that, the first collet looks the one you took a pic of - the extremes of the sizes - and the second one is two mid-size openings. If both are exactly the same, you might see about returning it because you can't use it like that. Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3926036 Share on other sites More sharing options...
Charlo Posted January 19, 2015 Author Share Posted January 19, 2015 Ah that sucks... :( what a hassle! I'll message the seller Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3926066 Share on other sites More sharing options...
Leonaides Posted January 19, 2015 Share Posted January 19, 2015 i wrapped the smaller bit in a little twist of paper - gives just enough purchase to allow the black part to grip it when you tighten it... If it helps any, i bought mine from GW about 10 years ago... Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3926079 Share on other sites More sharing options...
Charlo Posted January 19, 2015 Author Share Posted January 19, 2015 I managed to get the smallest bit into the smallest chuck with a bit of fiddling, now it works a dream! Just drilled out some bolt pistols and they look SO much better! Can't wait to get some magnets in my models Link to comment https://bolterandchainsword.com/topic/302289-pin-vice-woes/#findComment-3926102 Share on other sites More sharing options...
