Primarch killing suicide Moritat
Ok, this is thread contains a lot of 'ifs' in it and just meant as a bit of fun (also as a possible way of dealing with a friend who runs Horus with a large terminator bodyguard).
  • A moritat, with two plasma pistols, phase walker and combat augment array.
  • At the start of the turn declare use of the combat augment array.
  • 'Phase walk' near the primarch.  With the combat augment array any dangerous terrain tests shouldn't be a problem, as you count any dice roll as automatically rolling a 6.
  • Declare chain fire with the moritat and his plasma pistols, using the combat augment array to declare all your dice to automatically roll 6's.
  • Keep on shooting until you wipe out the primarch and any bodyguard.  Wait for your moritat to get revenge killed.
Is this a plausible thing to do or am I reading something wrong?  Obviously a definite one trick pony and only doable if the Primarch isn't in a vehicle but does this make sense?
https://bolterandchainsword.com/topic/302321-primarch-killing-suicide-moritat/
Bolter and chainsword was already on top of this.
This is FW response so the answer is no.
I have received a reply from FW regarding the Combat Augment Array.
Quote
Hi David,
Thank you for your email. We have just spoken to Alan Bligh about the Combat Augment Array Relic and this applies to only 1 single dice roll and NOT every dice roll that turn.
If there is anything further we can do to assist you, or if you have any queries about the information we have requested or provided, please telephone us.
Regards,
Forge World
Couple that with the Plasma Moritats nerf and well, its just not a feasible thing to do anymore.
Consider that, a Moritat geared that way would, at most, cost 250 points. If he could ERASE a squad worth EASILY 1k points due to a SINGLE relic in his arsenal, then Forgeworld has :cuss ed up hard in that respect.
Thankfully, they're good about getting back to us about rules queries so it has been figured out as the above Email states.
Or, be a Bolt Pistol Imperial Fists Moritat so that you get BS 6 and reroll any ones and hit again on a 6 thus giving you the potential to LITERALLY hit forever if RNGesus is truly on your side.
... so what, become a FPS player with infinite ammo?
Just model him with drum barrels :P
Or with an ammo feed from the Mags to the backback with ammo chutes on it.
Remember to say "420 noscope720dropshot" while playing a soundboard of Snoop Dogg "get high and smoke weed erry day", then walk off saying "get rekt m9" to get a free Victory Point.
Excuse me but I believe it goes -
Yolo Swaggins 420noscopeblazin. Gr8 b8 m8 I r8 8/8.
You're welcome.
http://new1.fjcdn.com/comments/To+start+understand+the+difference+between+the+ultramarine+chapter+of+_028924ba4d8fac6bfaa05f106063b827.jpg
Recolor that in Black and Yellow and turn the winged blood drop into a clenched fist.
