Necrons and Ghost Arks
Wait for the new codex. Annihilation Barges are going up in price (thank Throne) so he can't just auto-include them anymore.
Against Necrons I'd use Darkfire Castellax against his mech. S7 AP2 Lance with -1 to his cover saves (really helps against Jink) is very strong at causing pen hits, which is how you drop their stupid underpriced AV13 shield. Once that is down, it's a lot easier to cause damage to their normal AV11.
Thanatars vape their infantry just fine. You'll have problems against Wraiths though, they've recieved buffs in the new codex as well (T5...wth). I'd probably take Ursarax to deal with Wraiths, nothing else you have is good in melee.
Lance would override. It always checks the AV value of the target at the time you shoot it. The stupid shielding boosts them to AV13, but then Lance lowers it back down to 12. Hence, Darkfire cannons still rek Necron vehicles.
I'd really recommend Ursarax. New Wraiths are absurd, you won't kill them with shooting and they tear Thallax to shreds without even trying. Even Castellax don't wanna tangle with them, their low attack output means you'll be Rended to death eventually. Ursarax re-roll to wound due to their lightning claws, and their 5+ FNP means they'll stick around longer. They're also fast enough to intercept an assault, all other Mechanicum stuff is too slow.
wouldn't taking the powerfist be REALLY worth it against Wraith? Str10 instant kills them once the wound goes through...
4 attacks each on the charge all with str10 is fairly bonkers.
Speaking of...does anyone know why you would ever use the volkite incinerator in CC? I can't think of a single thing it would be more useful for.
Assuming they fail their 3+ invul. It's also a 10pt upgrade per Ursarax, who aren't cheap to begin with. Your lightning claws are usually going to be enough, wounding on 4's with re-rolls is pretty reliable, and there is nothing worse than rolling a 1 with a powerfist to wound.
Also, in the new formation with the Spyder and Scarabs, they get Reanimation Protocols for free. So, even if you do insta-gib with the powerfist, they get back up on a 4+. This is after they failed a 3+ invul too :(
mywords
Also, in the new formation with the Spyder and Scarabs, they get Reanimation Protocols for free. So, even if you do insta-gib with the powerfist, they get back up on a 4+. This is after they failed a 3+ invul too sad.png
Well insta-gib means Minus 1 to those reanimations...and I think in the formation they are 5+ (per normal necron reanimation without a cryptek) so that would force reanimations to a 6.
And yeah statwise they will fail those +3 once every three rolls. with roughly 2 instant death wounds forcing saves on wraiths per usarax, a squad of 3 with power fists should take down 2-3 wraiths pretty reliably the turn they charge right?
Sounds better than causing the same number of the same number of wounds (because even a 4+to wound re-roll 75% is not as good as 2+ without re-rolls 83%)
Well worth the points in my book! But to each their own to their lists!
As far as ghost arks though....ursarax with fists would punch it dead but the best thing is that gnarly Krios battle tanks with the pulsar fusil. (CAN I PLEASE GET THAT GUN ON A KNIGHT!??)
36" on a fast tank? 4 shots of Ordanance? Ap2 against open top so +2? Yeah they will wreck a ghost ark a turn without good cover/jink.
  • 2 weeks later...
Yeah, forgot about that. Instant Death does apply a -1 penalty. However, you're wrong about the base roll. Decurion grants 4+ Rez rolls by default, you never need Crypteks lol. So, against an Ursarax powerfist, a Wraith has to fail a 3+ invul, and then gets back up on a 5+. Also, if there is an Overlord nearby, he can re-roll the Rez roll if he rolls a 1. ;)
Should do. Remember, 3+ saves don't always fail the way you want them too. Marine syndrome is real. Sometimes you opponent will pass a bunch of 3+ saves in a row no problem. Other times they roll triple 1's lol
No I'm actually in agreement. I think powerfists are a very worthwhile investment. Unwieldy doesn't matter, Wraiths will have lash whips to ensure they go at I5 anyway (so they go first regardless).
Yeah Ursarax with powerfists will rip any tank to shreds. Pretty good against Necrons too, in that you will fight a lot of AV13/14 stuff.
Krios Venator wouldn't be good dude, because gauss reks tanks. Flare shielding doesn't save you, gauss auto-glances on a 6 to damage :( its like super-Haywire now.
Yeah, forgot about that. Instant Death does apply a -1 penalty. However, you're wrong about the base roll. Decurion grants 4+ Rez rolls by default, you never need Crypteks lol. So, against an Ursarax powerfist, a Wraith has to fail a 3+ invul, and then gets back up on a 5+. Also, if there is an Overlord nearby, he can re-roll the Rez roll if he rolls a 1. msn-wink.gif
Should do. Remember, 3+ saves don't always fail the way you want them too. Marine syndrome is real. Sometimes you opponent will pass a bunch of 3+ saves in a row no problem. Other times they roll triple 1's lol.
Krios Venator wouldn't be good dude, because gauss reks tanks. Flare shielding doesn't save you, gauss auto-glances on a 6 to damage sad.png its like super-Haywire now.
Eh even with a full ark firing if they are not in rapid fire range I am not nervous. The krios is faster. You will get to shoot first. Likely murdering an Ark and positioning yourself to at least take partial cover from return.
Not unless you are using something I'm unaware of the Wraith is not part of the Reclamation Legion and thus will not benefit from the 12" command rule of the Overlord.
Again, I keep repeating this all over the forum there are mini-Necron discussions but my Necrons definitely struggle most against numerous Marine armies that aren't going the 'elite' route.
The more elite in general an army is, the more it plays into Necrons' hands.
Just remember several of the formations have an anchor point that gives the rules. So in the case of the Canoptek Formation (FnP on the Canoptek formation). Remember at the beggining of the turn only units within 12" of the Spyder get those special rules. Most importantly as written, it can only be 1 Spyder in the formation (NOT a squad) and if you just kill the spyder, the formation is essentially broken.
Ghost Arks now get a Salvo 20 gauss flayer on both sides. So yeah, I'd worry. Because the Warriors inside can shoot as well. Trust me, Necrons have zero issue removing vehicles. Robots are better, you'll shrug off more damage by being T7/8 and having an armour save.
Ah good catch. Still, 4+ Rez.
The Canoptek Harvest Formation doesn't grant FNP. it grants Reanimation Protocols (or Shred, or Fleet). Which, due to being in a Decurion, means it's also 4+ Rez rolls.
If you focus on the Spyder, by definition you're not shooting the Wraiths, so effectively the Spyder has done it's job anyway. Also, good luck keeping it dead. T6 3 wounds and 3+ save, with a 4+ Rez roll on top of that.
If only that's how Modifiers worked, you would be correct.
Salvo 10. Unless you are folded around the Ghost Ark to be shot by both sides, they can only generate 10 Hits on a unit at the most. That may have been what you meant, but it sounded like you were saying it was Salvo 20 on each individual side.
Also keep in mind that the RP isn't the only rule that the Spyder can grant, just the one that will be used the most.
Having a real hard time with the list.  I am trying to take away the glance advantage and being shot by a million warriors from the ghost arks.  So far I have:
Magos Prime - Cortex controller, cyber familiar, powerfist, myrmidax, two plasma fusels and a jet pack
Magos Dominus - Vanilla
Myrmidon Secutors - graviton guns Bunker, escape hatch
Thallax Cohort 3 - Plasma fusels heavy chain blades destructor
Adseculoris Covenant 20 - right of pure thought
4 Castellax - mauler bolt canons, enhanced targeting
Thanatar siege enhanced targeting array, paragon of metal.
I can't decide if I should worry about air.  If I do I was thinking about adding a quad gun to the bunker or bringing an aegis defense line with a quad gun and an assassin to man it.
