Rommel44 Posted January 25, 2015 Share Posted January 25, 2015 Hey mates. Have gotten started working on my SOT Imperial Fist SM's at the moment and so far have about 3x Tac Squads, Sgt. Garadon, and 3x Drop Pods at the moment.And while I am at it, I have things set up for my first trial run at testing the Army Builder Demonic Yellow Primer on a few "Test Models". When it comes to this Yellow Spray, would it be better to do an undercoat of White Primer first or could I just prime it Yellow and not worry about the rest? Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/ Share on other sites More sharing options...
Dusktiger Posted January 25, 2015 Share Posted January 25, 2015 all of the army painter sprays are primers; you wont have to undercoat before spraying. i've used that one before, so be warned it's a very bright yellow. closest citadel paint is Yriel Yellow. but that's a tad darker than the spray paint. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3930909 Share on other sites More sharing options...
Slips Posted January 25, 2015 Share Posted January 25, 2015 all of the army painter sprays are primers; you wont have to undercoat before spraying. i've used that one before, so be warned it's a very bright yellow. closest citadel paint is Yriel Yellow. but that's a tad darker than the spray paint. Its Darker than Flash Gitz? Or Brighter? Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3930977 Share on other sites More sharing options...
Rommel44 Posted January 25, 2015 Author Share Posted January 25, 2015 all of the army painter sprays are primers; you wont have to undercoat before spraying. i've used that one before, so be warned it's a very bright yellow. closest citadel paint is Yriel Yellow. but that's a tad darker than the spray paint. Its Darker than Flash Gitz? Or Brighter? Its a very bright yellow. Just tested it on a test model and it came out very bright. Not bad, but I am looking for a bit darker then that, so I plan to prime it grey in order to make it darker then it originally looks, as I am not a huge fan of the super bright yellow-look. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931013 Share on other sites More sharing options...
Slips Posted January 25, 2015 Share Posted January 25, 2015 Just seraphim sepia or agrax earthshade around panels, should darken it up a bit. Or get some dark purple accents. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931029 Share on other sites More sharing options...
Jeff Newton Posted January 25, 2015 Share Posted January 25, 2015 I use sepia wash over the demonic yellow. It really takes the brightness down. Just watch to make sure when the wash is applied that you don't leave it sitting anywhere that is flat or it will look blotchy. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931424 Share on other sites More sharing options...
nortran11 Posted January 25, 2015 Share Posted January 25, 2015 I love the Army Painter Daemonic yellow. But I don't use the spray, I use the War Paint version of the color (it's an exact match of the color in the can though). I find the colored primer comes on very thick. So I spray a light coat of Tamiyia White Surface Primer and then hand brush two very thin layers of the War Paint Daemonic Yellow. For shading I brush on Army Painter Quickshade Soft Tone Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931510 Share on other sites More sharing options...
Rommel44 Posted January 25, 2015 Author Share Posted January 25, 2015 Looks pretty good, however I am looking for more of a Golden-Yellow Color then the brighter yellow, as I have always been a fan of that scheme for Imperial Fists. Anyone know how I could accomplish that? Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931568 Share on other sites More sharing options...
Slips Posted January 25, 2015 Share Posted January 25, 2015 The Brightest yellow I can think of is Flash Gitz Yellow. You can then Glaze it with Lamenters Yellow to really bring out the pigment. Or you could go white Primer/Base and just slap on several layers of Lamenters Yellow. This is only with 2 Coats of Lamenters Yellow, mind you. Picked out the details in Seraphim Sepia before slapping on the Lamenters. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931592 Share on other sites More sharing options...
Dusktiger Posted January 26, 2015 Share Posted January 26, 2015 Looks pretty good, however I am looking for more of a Golden-Yellow Color then the brighter yellow, as I have always been a fan of that scheme for Imperial Fists. Anyone know how I could accomplish that? were you thinking something more like this? Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931659 Share on other sites More sharing options...
Rommel44 Posted January 26, 2015 Author Share Posted January 26, 2015 Something along the lines of this is what I am looking for. Here is the link: http://www.centerpieceminiatures.com/more-imperial-fist-completed/ Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931665 Share on other sites More sharing options...
Slips Posted January 26, 2015 Share Posted January 26, 2015 Phalanx Warder: http://www.bolterandchainsword.com/user/63665-phalanx-warder/ Has gotten a pretty nice recipe based off the Forge World Imperial Fists Scheme; I think its more along the lines of what you're looking for. Shoot him a PM if anything. http://www.bolterandchainsword.com/topic/292010-imperial-fists-painting-a-noobs-plea-for-advice/?p=3714535 Here is a post where he (Phalanx Warder) talks about using the FW Scheme http://www.bolterandchainsword.com/topic/292010-imperial-fists-painting-a-noobs-plea-for-advice/?p=3714535 And the Scheme itself when I asked Forgeworld for it and was looking from Opinions from the Frater on how to go about getting a nice yellow. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3931670 Share on other sites More sharing options...
jeremy1391 Posted January 27, 2015 Share Posted January 27, 2015 Daemonic yellow doesn't need an undercoat, but give it a sepia wash after and you will be happy. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3932633 Share on other sites More sharing options...
Armfelt Posted January 27, 2015 Share Posted January 27, 2015 I would almost recommend to lay an undercoat before Daemonic Yellow. Atleast on larger models I have needed to spray several times to make it cover. Undercoating the model first can save you some yellow paint and time. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3932930 Share on other sites More sharing options...
Jeff Newton Posted January 27, 2015 Share Posted January 27, 2015 I prime black undercoat white making sure to fully coat the high areas but not so much the low ones. Then 3 very light coats with demonic yellow spray. Each time making sure that it is as light as possible because it builds up very quickly. Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3933195 Share on other sites More sharing options...
Gresiloth Posted February 10, 2015 Share Posted February 10, 2015 If you want a rich golden yellow, I don't think there's any genuine shortcut to building it up layer by layer, by brush. Yellow is such a translucent colour that the previous layers will always inform the final look. I spray mine black and then apply Averland/Yriel/Flash Gitz by brush... Dorn will be proud of your masochism! Link to comment https://bolterandchainsword.com/topic/302546-painting-imperial-fists-demonic-yellow-spray-army-builder/#findComment-3946001 Share on other sites More sharing options...
