Arkangilos Posted January 29, 2015 Share Posted January 29, 2015 So a while back I had bought that box set that had the Orks and the Space Wolves, and I gave my friend the Space Wolves. He's not sure exactly how he wants to build his terminators, what are some of the most fun and optimal builds you guys had with them? Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/ Share on other sites More sharing options...
Lord Blackwood Posted January 29, 2015 Share Posted January 29, 2015 Theres a bunch of TDA loadout threads in this section of the board you probably should search those up for detailed explanations. That being said short answer is that it depends on what other models he has and what sort of army he is building / how he plans to get them onto the board. Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3934512 Share on other sites More sharing options...
Vykryl Posted January 29, 2015 Share Posted January 29, 2015 If it's 5 Terminators give them all Wolf Claws and run them as the Void Claw formation. Get +1 weapon skill and deep strike in on turn 1. Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3934514 Share on other sites More sharing options...
Spazmonkey Posted January 29, 2015 Share Posted January 29, 2015 Dont forget the Voidclaws also give And re-rolls on reserves. Though I think if you only run a unit of 5 then you need an IC in there like Arjac to beef them up. I like to run 7 if not using an IC to give the extra power and durability If your not running them with Arjac or a wolf priest. Also you can not go wrong with Hammernators or Arjac's shield brothers (assuming you have the models) WS5 and T5 termies with hammer of wrath and the saves giving automatic hits rule = nasty termies Arjac and his Hammernators are fun... Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3934520 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted January 29, 2015 Share Posted January 29, 2015 You need a Land Raider to make Arjac's Shield Brothers work. I think either of these suggestions are good ones. You might want to consider a combi melta pack if he has the bits for it. End of Line Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3934624 Share on other sites More sharing options...
Wulfgar Ironmane Posted January 29, 2015 Share Posted January 29, 2015 Voidclaws or use magnets.save the other arms to switch em out whenever you feel like it. Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3935096 Share on other sites More sharing options...
Yoyo ninja Posted January 29, 2015 Share Posted January 29, 2015 I built mine for Alpha Strike, all with combi weapons (magnetised so I can take plasma or melta), 3 have fixed storm shields and 2 are magnatised at the wrist so they can take storm shields or power/frost weapons. They get delivered in a drop pod. When they land something gets blasted off the board then they just strole around back field being a pain in the ass. Due to 2+/3++ saves they are hard to shift and often draw a lot of fire which tends to leave the rest of your forces relatively unmolested. I also have some combat termies that don't tend to see much use these days. Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3935298 Share on other sites More sharing options...
tylerw Posted January 29, 2015 Share Posted January 29, 2015 I would recommend doing some sort of flexible arms at least. I'd try to magnetize at least HALF of the arms (so you can swap Power Weapons for Storm Shields at least), and do things like a Power Fist with a SS attached (or magnetized!) to the back of that arm - you can always PF it up with that arm as well that way. Were I to just glue together 5, I'd go for rule of cool, with stormbolters, but try to include at least 1 Power Axe, 1 Power Sword, and something to serve as a Power Maul (maybe a thunder hammer, I guess - not entirely a different concept) - that way you can easily get that mix of them in your list. Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3935309 Share on other sites More sharing options...
Arkangilos Posted January 29, 2015 Author Share Posted January 29, 2015 Thanks guys! Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3935422 Share on other sites More sharing options...
Nova_chron Posted January 29, 2015 Share Posted January 29, 2015 A unit I really love is wolf claw storm shield for hunting MCs and just being a general pain in the arse of most castled armies Link to comment https://bolterandchainsword.com/topic/302731-space-wolf-terminators/#findComment-3935433 Share on other sites More sharing options...
