jimbo1701 Posted February 1, 2015 Share Posted February 1, 2015 Hi folks, Been a while since I posted here but I thought this project was worthwhile sharing. I'm fanatical about Space Marines but first amongst equals are of course Blood Angels. They were my first army back in the day of second edition and have always been my first love in 40K. Amongst my armiesmy Blood Angels are the largest, comprising around 160 models including the entire 5th company. With the advent of the new codex the army has undergone a massive revamp (no pun intended), with me replacing almost half the battle company with new parts from the new kits. However, I always had one project I wanted to undertake should they not produce a new mephiston sculpt, and that was making a conversion based on (in my opinion) the iconic artwork of mephiston from second edition. For those not familiar, this is the one: http://wh40kart.im/_images/55f23df0973cb99be07f6da10da7f049.jpg When compared to the mephi model, this chap is obviously much more dynamic, with the cloak flowing, head repositioned, right arm sans pistol and raised and left sword arm lowered. I had oriinally thought about using astorath as a basis for the conversion, but then along came the sanguinary priest model and I knew I had to use that as the basis for the conversion. So, effectively what I did was chop mephis head off, removed the right arm at the shoulder and painstakingly cut out the entire of mephis legs while leaving the cloak intact. The head was replaced with one of the new fanged sergeant heads, and guitar wire used to attach the psychic hood cables to his head. In the case of the right side I replaced the entirity of the cable with guitar wire, the left only the part inside the hood. I later GS sculpted some hair to flow in the direction of the wind blowing the cloak. I also decided that as well as a BA backpack he needed a banner to later have his heraldry displayed on. As for the cloak, I heated the finecast in warm water and made it appear to be flowing more towards the right as if blown in the wind. Between removing the legs and heating the cloak it did split a bit so I had to fill the gaps with GS. The legs were replaced with a painstakingly shaved down set of legs from the priest model. I was tempted to try and seal up the gap at the front and make it more like the original image, but decided I quite liked it with the parting and so saved myself a job. The left arm was repositioned using a bit of generic space marine elbow and greenstuff. Likewise, pretty much the same was done for the right, with the hand modified to look like mephi is about to lick the blood (to be added later using techincal paints) from his fingertip, with the plasma pistol presumably holstered. Aside from all this, a bit more filling and GS work and voila, here he is just about ready for spraying: http://i163.photobucket.com/albums/t286/jimbo1701/IMAG0406_zps7xvrawak.jpg I'm really happy with how he turned out so far and am going to inspect him a couple of times prior to spraying to make sure I have no outstanding issues. I may also just use a bit of abaddon black over the GS areas to check they're smooth prior to spraying. So what do you guys think? Comments and crits appreciated as always. Cheers. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/ Share on other sites More sharing options...
Jorre Posted February 1, 2015 Share Posted February 1, 2015 This is brilliant! Can't wait to see some paint on him! Who's legs are those? After reading the whole post (duh) I found the answer to my question Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937450 Share on other sites More sharing options...
Rizara Posted February 1, 2015 Share Posted February 1, 2015 The legs are from the new sanguinary priest, you can tell because of the vials at the waist sort of a dead giveaway. Nice conversion, paint will make it amazing, I assume you are also going to add the single finger sticking out too? Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937525 Share on other sites More sharing options...
jimbo1701 Posted February 1, 2015 Author Share Posted February 1, 2015 Thanks guys, the finger is already there just the angle makes it hard to tell it from the hair. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937532 Share on other sites More sharing options...
Olis Posted February 1, 2015 Share Posted February 1, 2015 Superb likeness, brother. I don't suppose you are planning on filling the gap in the cloth of his robes? Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937534 Share on other sites More sharing options...
Bagsy Posted February 1, 2015 Share Posted February 1, 2015 That is a model I would go and buy right now if it were on the shelves!! A great job I can't wait to see it painted Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937542 Share on other sites More sharing options...
jimbo1701 Posted February 1, 2015 Author Share Posted February 1, 2015 Hi olis, really considered it for a long time both to make it more like the picture and make it look different from a sanguimary priest. Problem is that I'm terrible at sculpting smooth flat surfaces and that both sides of the robe flow outwards so I'd have to chop a lot off before filling to make it look right. I figure it's just mephi wearing his Sunday bests. ;) I also considered sculpting the syringes but figured mephi had taken some time out from his haemi-roids for now and thus lost a bit of strength/toughness and a few wounds! Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937544 Share on other sites More sharing options...
TheHarrower Posted February 1, 2015 Share Posted February 1, 2015 Man is that a great conversion. Looks really awesome. I thought those legs would be perfect for Mephiston. Turns out they are! Can you add this to my Special Characters Conversions Thread here: http://www.bolterandchainsword.com/topic/300271-post-blood-angel-special-character-conversions My only critique would be the hair. It's tough to tell since its green, but something looks off about it to me. Maybe it's that it doesn't look like it's coming out of his head and more stuck to the side of it? I don't know, maybe I'm crazy. In any case amazing job. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937560 Share on other sites More sharing options...
jimbo1701 Posted February 1, 2015 Author Share Posted February 1, 2015 Hi guys thanks again for the comments. I've decided to go ahead and add some paint to him having done some liquid gs work to various places. Once he's got some base coats on it should be easier to tell what's what with him and I'll add him to the character blog. Will post a pic tonight. Cheers. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937588 Share on other sites More sharing options...
Khorneeq Posted February 1, 2015 Share Posted February 1, 2015 Great model and using hot water for reposing cloak is such a brilliant idea :D As the artwork is black and white, what colours will You be using? Standard codex or some succesor? Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937614 Share on other sites More sharing options...
jimbo1701 Posted February 1, 2015 Author Share Posted February 1, 2015 Will go with a scheme similar to the mephiston in the new dex I reckon. Purple lining to the cloak and red with blue interior (librarius) for the banner. Mostly shade of red with black cloak and gold detailing. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937641 Share on other sites More sharing options...
Crusader Bob Posted February 1, 2015 Share Posted February 1, 2015 Brilliant conversion. That's a Mephiston i would like to use. And i hate witches. Can't wait to see it painted, i'm sure is going to be awesome. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937647 Share on other sites More sharing options...
Xenith Posted February 1, 2015 Share Posted February 1, 2015 Awesome conversion, great work! Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937663 Share on other sites More sharing options...
Brit Viper Posted February 1, 2015 Share Posted February 1, 2015 That is an awesome covertion. Can't wait to see it painted. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937676 Share on other sites More sharing options...
walpurgisnacht Posted February 1, 2015 Share Posted February 1, 2015 I feel the mini needs a microphone in his right hand. Looks like a black metal vocalist. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937696 Share on other sites More sharing options...
jimbo1701 Posted February 1, 2015 Author Share Posted February 1, 2015 I feel the mini needs a microphone in his right hand. Looks like a black metal vocalist. Brilliant, hadn't spotted that before. Oh well, if Orks can have Goffik rokkerz... Here's as much as I'm gonna be able to get done today, just a few basecoats in places to get the idea. Cheers. http://i163.photobucket.com/albums/t286/jimbo1701/IMAG0406_zpspt5vo7lu.jpg Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937720 Share on other sites More sharing options...
marine7312000 Posted February 1, 2015 Share Posted February 1, 2015 That is an awesome model. I got one of the new Priests and now I'm really debating picking up a finecast Mephy to chop up. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3937941 Share on other sites More sharing options...
Njjesters4 Posted February 2, 2015 Share Posted February 2, 2015 Really nice work so far Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938231 Share on other sites More sharing options...
Chesco Posted February 2, 2015 Share Posted February 2, 2015 Wow, that is almost exactly the conversion I have had in my head for the last couple weeks! Well done. Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938237 Share on other sites More sharing options...
Ushtarador Posted February 2, 2015 Share Posted February 2, 2015 Absolutely awesome! :D Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938373 Share on other sites More sharing options...
TheHarrower Posted February 2, 2015 Share Posted February 2, 2015 Now that there is paint on there, hair looks fine. Awesome job! Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938623 Share on other sites More sharing options...
Angelus Mortifer Posted February 2, 2015 Share Posted February 2, 2015 Excellent job mate. Top stuff Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938633 Share on other sites More sharing options...
ContemptuousAngel Posted February 2, 2015 Share Posted February 2, 2015 Wow! Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938773 Share on other sites More sharing options...
frozenjordan Posted February 2, 2015 Share Posted February 2, 2015 Great work! Most importantly this conversion probably brings Mephiston to "adult height" which is a huge thing compared to the actual model. Cheers! Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938808 Share on other sites More sharing options...
jimbo1701 Posted February 2, 2015 Author Share Posted February 2, 2015 Hi guys, thanks for the kind words. Some minor progress, almost finished basecoats and started washing. Hoping at this rate he'll be done by the end of the weekend, at which point I'll take some better photos and add him to the other thread. Cheers. http://i163.photobucket.com/albums/t286/jimbo1701/Mobile%20Uploads/IMAG0408_zpsd9tlquyj.jpg Link to comment https://bolterandchainsword.com/topic/302862-mephiston-conversion-based-on-2nd-edition-artwork/#findComment-3938887 Share on other sites More sharing options...
