JamesI Posted February 9, 2015 Share Posted February 9, 2015 So bolt pistols with chainswords and power swords, bolters with fists and thunder hammers , is that ok? Yeah, pretty much. I sometimes add 1 extra bolter to a chainsword guy, but that just comes down to what I feel like. Link to comment Share on other sites More sharing options...
shandwen Posted February 10, 2015 Share Posted February 10, 2015 Im planning on a ten man unit with one TH, one power sword, and two or three melta pistols. With the jump packs the unit will be highly flexible, not horrible overkill, and be able to tango with most units. Link to comment Share on other sites More sharing options...
Xenith Posted February 10, 2015 Share Posted February 10, 2015 So bolt pistols with chainswords and power swords, bolters with fists and thunder hammers , is that ok? Well, it's ok in that it gets you the most shots/attacks. The pistol doesnt give you any more attacks with the fist, so you may as well use a bolter. Using a bolter with a power sword is a waste, as you dont get the bonus attack, so use a pistol. Normal dudes get bolters or pistols, depending on what you want the squad to be doing. Coming out of a transport, bolters are a good idea so they can shoot stuff to full effect. The bolt pistols grant more attacks in combat. Link to comment Share on other sites More sharing options...
DominicJ Posted February 11, 2015 Share Posted February 11, 2015 I over load on bolt guns, just because I shoot a lot more than I expect to, You can expect to shoot 6 turns, you might get in to CC for three phases. Admitadly, with bp/cs and the charge DC should be killing terminators (or anything else for that matter) before they swing back point for point Link to comment Share on other sites More sharing options...
frozenjordan Posted February 11, 2015 Share Posted February 11, 2015 Bolters are a great way to make good use of "Relentless". Double tap charge. Link to comment Share on other sites More sharing options...
Charlo Posted February 11, 2015 Share Posted February 11, 2015 Bolters are a great way to make good use of "Relentless". Double tap charge. Just got to be careful as to not kill too many to gib your charge distance! Link to comment Share on other sites More sharing options...
