Adverse effects of sunlight on painted models
Ultrad81
Hi all
Thought's been bugging me for a while - anyone any idea whether sunlight is likely to have any adverse effects on painted miniatures (e.g. bleaching, fading etc) after a significant time out in the open?  I tend to have my unvarnished dudes out in a glass display case when they're not being used, and not noticed any degradation myself, but wondered if anyone's experienced any problems, either with the GW paints or any of the other common alternatives?
Cheers :)
Although it IS possible for sunlight to affect minis over time by fading, it is usually an insignificant amount to notice. In my many years of painting (20+), I have seen very little fading of acrylic paints over the years. I have seen some inks fade a little more, but the acrylic binder seems to be a bit more lightfast with paints. When using Micron pens, I've seen more fading on minis that were un-sealed/un-varnished… Which brings to a different issue-- Depending on which sealer/varnishes are used, I have seen some instances where the sealer/varnish yellows with age, slightly changing the colors perceived of the paint beneath.  Usually, Testors Dullcote and Glosscote are known to be fairly resistant to yellowing over time. YMMV.
Great, thanks for the info, the cabinet shall stay where it is!  Weirdly I hadn't even considered that the varnish could discolour as well - useful to bear in mind.
EDIT: Btw apologies for the title of this thread which sounds like some kind of scientific research paper.   I've spent this weekend writing a uni assignment and need sleep...
