Painting with pens
Stercus
As it says in the title really. I've seen a few guys (and girls) on here that do fine text and the line with some sort of pen, rather than a brush. Now, I'm assuming it's not a sharpie or anything by crayola, so the question is, what type/brand/size is best to buy?
Thanks in anticipation.
https://bolterandchainsword.com/topic/303368-painting-with-pens/
I've used both Micron and Sharpie pens as well, the brand doesn't so much matter as the point size (smaller the better). Most folks just use black since it's a pretty standard color for text on scrolls and seals, I sometimes use other colors on scrolls to make them pop.
As mentioned, Sakura Micron are the most common and what I started with. I've evolved to using the Copic Multiliner line; don't let the price scare you away, they are refillable and the tips are replaceable, both at a reasonable price. Brand is less important then making sure it's a permanent ink. There are tons of great fine tipped pens out there, but they are intended for use on paper products and will never dry properly on a miniature. Even labeled as permanent, results will vary on just how fast the ink will hold; be sure to put a protective coat of some sort over pen ink to unify their colour to the paint (sometimes they'll miss-match, but varnish fixes it), and to lock the ink and protect it from smudging.
To be honest, I'm getting confident enough with brushwork to do most actual text in paint, but my main issue is when adding teeny-tiny functionally unreadable text to purity seals, banners and suchlike. I can't get a neat enough 'wiggle' with a brush to suggest writing without covering my models with smudges and blobs. This vexes me greatly.
Do you think I'd need to varnish a purity seal?
