What strips paint from a fine-cast resin model?
I just stripped some from eBay with 91% rubbing alcohol, took about 4 hours soaking in it, then ran under the sink and used a medium toothbrush.. I had no residue and no damage. Can't speak for everyone though because there's different types of paint, techniques, etc
Do not use anything with Acetone in it. I'm fairly sure Nitromors and Brake Fluid will be on the no-no list, too. If you're on my side of the pond, then Dettol (brown) will probably work, as will Fairy Power Spray. If you live on the other side of it, then as Mehman said Simple Green is the stuff you want.
