Ulrik or Wolf Guard Battle Leader?
Skallagoose
Ok guys, I have a biannual tournament coming up next month and i am making some final touch-ups to my army. I have about 150 pts flexible in my list and i need to submit a list shortly. its a 1500 highlander tournament (but modified rules slightly).
I was trying to make about 150pts worth of rapiers, but scratch building them is going to take too long. So I'm stuck in a pickle...
I have two lists right now, and as the topic title suggests, I'm stuck between Ulrik or a WGBL. Ulrik is Ulrick, while  WGBL build is; Runic Armor, Storm Shield, Combi-Melta, and Krakenbone sword.
Either way i will have this character in a drop pod with Cents in it. I found Cents are amazing with a wolf drop pod- but they can get overrun through assault. What do you guys think would make a cents deathstar more effective; Ulrik or a close combat surviving WGBL?
https://bolterandchainsword.com/topic/303421-ulrik-or-wolf-guard-battle-leader/
Does your WGBL have three arms, or am I missing something somewhere?  Shouldn't the KBS replace one of your weapons?
he does! haha, no you're right, i didnt catch it before but battle scribe let me do it (fingers blame at an ap). So remove the combo-bolted. but on the entry page for the champions of fenris relics it doesn't say "replace a weapon with…" Just a rules lawyer in me coming out. The actual lawyer in me would say look at the intent of the writers.
WGBL; SS/Krakenbane sword
I think you're going to be misusing ulric because i don't believe he passes on his PE or Monster Hunter to units other than space wolves. He's also not nearly as tanky as your proposed battle leader.
I do not plan on having him as my warlord so he wouldn't have monster hunter, but isn't the rule for PE if an allied wolf unit within 6 inches (including himself), and the rule for PE itself says "at least one model in the unit" give the whole unit re-roll 1's to hit and wound?
Space Marines and Wolves are battle brothers and as such he, as an IC, can join them.  Ulrik's rule says that he AND his unit have PE. PE rule says any model gives it to the unit so I'd say you're correct. The unit gets it but only nearby Wolves benefit from the 6" portion of his ability.
I tend to look at Ulrik as a force multiplier. If you were running this model out solo then I'd say WGBL. However I'm currently 'sold out' on Ulrik when he and 10 blood claws smashed 2 carnifexes (sp?) this weekend. They may have done well on their own but PE made a big difference in scoring hits. Did I mention Ulrik just looked on both times? He never even got to swing his Crozium. Plasma pistol with rerolling ones mitigates 'Gets Hot' as well so you've still got the high STR low AP 12" range as well.
Ulrik if he does indeed give your allied centurions PE.
Rerolling all your ones to hit/wound in shooting makes your cents even more deadly than they were, and then they get those rerolls in CC too. Oh and fearless and 6+ FNP (i think???)
Have you considered giving the drop pod the IA upgrade that means it doesnt scatter?? Means you can land 23" away from a target and still shoot all your grav gubbins (which should then leave you out of range of charge for most things f you are clever about your placement).
Is the rule not along the lines of 'ulrik and any friendly space wolves unit within 6" gain preferred enemy (everything)." though?
- In which case ulrik always has the preferred enemy (wether he is with a SW unit or not)
- as an IC character can join the centurions (as they are battle brothers)
- He then passes PE on to them as per the PE/IC rules in the BrB?
(note - i have neither the codex or the BrB to hand haha)
The main thing i could see with the issue here is wether ulrik actually gives PE to himself, or just to other space wolf units.
MH passes on. His bubble does not.
However, I am wondering why this is an issue. Ulrik and WHBL have completely different functions.
Ulrik is a force multiplier for pod heavy SW army back field shooty spam.
WGBL is a cheap HQ that can act as a meat shield, decent combatant or mandatory tax.
They have rather little in common except that they occupy the same slot.
haha i am amazed how much comments this drew already. Im 90% sure he gives PE to cents through having preferred enemy himself.
The question to start with was whether it was better to give the buffs to the cents from Ulrik or to have a meat shield in the form of a WGBL.
He passes PE on, that is correct. I am just saying that non-SW units are not affected by the actual bubble :P
And your question can not be answered. What is your list? Only once we know your list can we comment what is missing and whether you need PE or meat-shield.
He passes PE on, that is correct. I am just saying that non-SW units are not affected by the actual bubble tongue.png
didnt want to put this in the list forum, just a simple answer to a complex question; but i see your point.
very quick run-down.
Champions of fenris;
Harold Deathwolf (warlord)
Rune priest lvl 2
(either Ulrik or meat shield)
Elites;
Iron priest- thunder wolf mount, 4 cyberwolves
servitor
Fast Attack;
Drop pod
Thunderwolf Cav- x5. Leader with wolf claw (accept challenges) and one with a power fist. All have storm shields
Allied detachment
Red Scorpions
HQ- Magister Sevrin Loth
Troop- Tac squad; rhino, plasma gun
Heavy Support- Centurion Devastator squad
Ulrik. Cents get the bonus when he is with them, TWC get the bonus when they reach the front lines. In this case he beats WGBL any day.
I am not a fan of Harald. I prefer a 2+/3++ tank this is really up to your preferences.
I would also you to get an Apothecary for Tacs (red scorps CT) to keep Loth save. He will be a bitch to kill with 2++ and FnP. To finance the Apoth I would l skip some SS on TWC. Choose his powers from Biomancy most of the time. You want Iron Arm on self and Endurance on focus target. Third power is optional.
Chapter tactics for red scorps makes the squad leader an apoth- no need to upgrade (its a no cost bonus). I also would prefer a 2+/3++ but i wouldn't have the set amount of points, and Harold's trait really helps my wolves. For instance- my wolves last game took down an imperial knight at initiative 4. I did several wounds to it prior to charging, but then S6 charge, Rending… 2 hits went through, enough for the kill.
Again- i wasn't planning on running either of these hero choices tho. I was in the process of scratch building 3 rapier weapons- but i do not see it as being feasible to finish in the next few weeks.
Just to float this, but doesn't the codex say you may take a storm shield not, you may replace a weapon with a storm shield...?  I haven't got mine here to double check...
Ok cool so just for my own clarification (as i already use ulrik a lot so want to make sure im using him right).
He gives pref enemy to any space wolves withing 6"
Any unit he joins gets preferred enemy due to it being passed on.
If he is taken as a warlord, he also passes on monster hunter to any unit he joins.
He is also fearless.
Also grants a 6+ FNP.
In this case - id definately take him in the centurion drop pod, as your making that horrible grav death even more horrible. Sure a WGBL could tank some wounds but their damage output with Ulrik in is gonna be daft. Especially if they end up having to deal with MCs.
Turn two your thunderwolves should be up the board to support them anyway, so just try to not land them right next to your opponents best CC unit msn-wink.gif
Centurions do not really get much benefit from Monster Hunter. They re-roll to wound anyway. PE is decent enough. Ulrik dies too fast to be Warlord though.
I also would argue that Ulrik will not benefit from his own bubble when with the Cents, but that is a whole other can of worms.
I don't think its even an argument because of the reading the codex; "Slayer's Oath; Ulrik the Slayer, and all friendly units with space wolves faction within 6" of him, have the preferred enemy special rule." Remove the part in the comas; 'Ulrik the Slayer ha(s) the preferred enemy special rule'. Then the rule for PE gives it to the whole unit if one does.
I submitted two different copies of my army list to the T.O. One with 3 rapiers and 1 with Ulrik.
Thanks everyone for your assistance! Look forward to playing these lists
