paulJam Posted February 14, 2015 Share Posted February 14, 2015 [edit: changing this to be random stuff i've made as they're generally not worth separate posts] greetings brothers, an idea i had a while ago, and prompted by a topic about dice. got problems shooting straight, use a scope... got problems rolling scatter dice next to your unit, use a rollinator... could you? yes, it actually works quite well. would you? probably just more board top clutter. made from scraps. thick cardboard and wood glue. the inside contains downward sloping ledges that the dice bounces down. not to scale, just shows concept. Link to comment Share on other sites More sharing options...
AndrewChristlieb Posted February 14, 2015 Share Posted February 14, 2015 I've never had a problem with this myself, but it looks pretty cool! Link to comment Share on other sites More sharing options...
Hyuzanriu Posted February 14, 2015 Share Posted February 14, 2015 My only problem is getting my regular opponents to just roll their scatter next the unit they are targeting instead of on the opposite side of board then guestimating which direction the template went. Link to comment Share on other sites More sharing options...
paulJam Posted February 14, 2015 Author Share Posted February 14, 2015 My only problem is getting my regular opponents to just roll their scatter next the unit they are targeting instead of on the opposite side of board then guestimating which direction the template went. then today is your lucky day sir!! step right up and see the latest in random probability cube containment technology. no one needs heated seats... well maybe ice-road truckers... but they exist anyway :) and it killed a few minutes while i was waiting for something else to dry. Link to comment Share on other sites More sharing options...
paulJam Posted August 1, 2015 Author Share Posted August 1, 2015 printed out a couple of these (own design) to see if they work. they do. necessary? not really. made 25mm, 40mm and 65mm variations, just because. btw my models all have metal washers in the bases to actually make this work. a pain to do? yepper, but i've started now (still a WIP, all sm done and any new models in other armies). Link to comment Share on other sites More sharing options...
paulJam Posted August 2, 2015 Author Share Posted August 2, 2015 was just a matter of time really... results so far. dotted line is where the ejection port is. haven't done much of anything with the facings as yet. just happy to be done with the printing. working out how to attach the facings, should have put some attachment holes on the 3d stuff.... next version. still working on the details... Link to comment Share on other sites More sharing options...
Andvarr A Posted August 2, 2015 Share Posted August 2, 2015 Barmy dude (⊙_⊙) just barmy. I like the idea of the dice dropper tho. Link to comment Share on other sites More sharing options...
paulJam Posted September 17, 2015 Author Share Posted September 17, 2015 still very much a work in progress. next is make the ejection port cover which also needs to stop the mag sliding up too far. and the outer cover/casing. and recess all the screws. and make it prettier... etc then refactor the changes into the sketchup models. haven't been able to do much over the last three weeks due to a busted paw, but the dexterity is coming back and pain less frequent. miss it. Link to comment Share on other sites More sharing options...
paulJam Posted September 21, 2015 Author Share Posted September 21, 2015 structure done. now just need to make it pretty. time to break out the bog and paint. slide works but only as a visual effect. trigger has a click mechanism but just for the sound. mag lock holds mag in - functional. Link to comment Share on other sites More sharing options...
paulJam Posted September 29, 2015 Author Share Posted September 29, 2015 metalic (spray) paint seems to have come a long way since i last painted a toy gun... Link to comment Share on other sites More sharing options...
Olis Posted September 29, 2015 Share Posted September 29, 2015 Looking good enough to be a cosplay prop, I think. ^_^ Link to comment Share on other sites More sharing options...
paulJam Posted September 29, 2015 Author Share Posted September 29, 2015 ta... and if only that was my excuse... Link to comment Share on other sites More sharing options...
paulJam Posted September 30, 2015 Author Share Posted September 30, 2015 so this is as far as i'm taking the project. has some ugly spots if you get too close, but given it was just an time filler experiment... meh. you'll have to take my word that the 'clickity-click trigger' is truly spectacular !! the end Link to comment Share on other sites More sharing options...
