Lucious patern pod
Fangbanger
The forgeworld one is bigger, but unless you're up against people who really care about their precious forgeworld investment being the thing that allows them to use the cool rules then it doesn't matter I'd say. (This coming from a guy who used a large blast marker as a drop pod in his last game ;) )
I don't see why it should make a difference.  In the fluff, the pods themselves should be the same size - after all, they would use the same launch mechanisms.  A dreadnought should fit inside a normal pod, and honestly you should just be able to model it without all the harnesses and stuff inside.
The real issue would be the rules.  The codex says a drop pod can carry a dreadnought - it does not say a special pod is required.  In fact, the entries for Dreadnoughts specifically refer to the Drop Pod from page 74 as the dedicated transport.  If you run across a rules lawyer, use the explicit rules against him.  WYSIWYG doesn't even factor into it - what you see is a drop pod, what you get is a transport that can carry 10 troops or 1 dreadnought.  No reason that you should have to buy a FW model when the GW model should do.
Honestly, I don't even see why a drop pod model should be required.  After they land, they are static terrain.  I've avoided drop-heavy army lists specifically because I don't want to spend a couple hundred dollars on "terrain" that's too big to fit in my army bag.
OK, so not just a regular drop pod transporting a dreadnought, but some pod that works differently in some way?  I don't do much FW stuff - they're the only source I know that makes GW product look "inexpensive", not to mention the difficulty obtaining it stateside.
That said, I don't see a major difference in the vehicle.  Aside from not having the interior harnesses, what's the real difference in the model? Yes, you can actually stand a dreadnought within, if it has no banner.  But that's not a requirement.
I don't see any reason why you should not be allowed to convert a GW model to this pattern - and any opponent who was a stickler had better hope none of his miniatures are conversions that contain "unofficial" parts, right? :)
I personally wouldn't mind someone proxying. The completionist in me wants to get the real deal from forgeworld but theyre so pricy.
Tournament wise, it is probably a no-go. Outside tournaments, YMMV but it doesn't seem too unreasonable to proxy (though you may complicate matters if the Lucius is indistinguishable from normal pods and you field those too)
Yeah the Lucious is bigger and so I think in a tourney you woukd have to use the exact model. I can't see anyone minding in a friendly though.
As for rules wise, it gains shrouded the turn it arrives and also gives it to the dreadnaught if it disembarks. It also allows the dread to sit inside it for a turn and then disembark and assult the next.
I think it previously had better rules but that us what it can do currently.
Think about how I would use ut though, I feel it is actually more of a hinderance but will defo give a whirl
Get those big lucozade bottles, chop the top off, turn upside down, selotape back together. Spray Black. Pretty much perfect size/shape for proxying droppods if you want to play around with them without first shelling out cash.
As for the lucious, aye the actual model is slightly bigger and actually fits a dread, so that first turn where the dread stays inside (since they changed the rules) at least you can have accurately portrayed on the table. And th ebigger the model the better cover its giving to other things too.
Me i wouldnt mind though, but yeah, tournaments will probably want the proper model.
Cos once they arrive, although static, they can make shooting attacks, or simply be used to block areas of the board, or provide cover for your own troops. All of which you need a model for. Sure proxy it out of card or whatever if you want, but you still need something on the board.
