NightGlow Posted February 19, 2015 Share Posted February 19, 2015 I recall one of the Horus Heresy books saying that the Palatine Blades colored parts of their armor platinum. I've been trying to make a platinum-ish color, or at least a silvery white without success. Do y'all have any advise on the matter? Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/ Share on other sites More sharing options...
Father Mehman Posted February 19, 2015 Share Posted February 19, 2015 Leadbelcher base Nuln Oil wash Ironbreaker layer White Scar wash (1:5 water) Runefang Steel highlight Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/#findComment-3955718 Share on other sites More sharing options...
NightGlow Posted February 19, 2015 Author Share Posted February 19, 2015 Leadbelcher base Nuln Oil wash Ironbreaker layer White Scar wash (1:5 water) Runefang Steel highlight You sir are a gentleman and a scholar, and you have my thanks. Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/#findComment-3955736 Share on other sites More sharing options...
Kaedes Nex Posted February 19, 2015 Share Posted February 19, 2015 I have literally never heard of or seen what a white colored wash can do. Would anyone happen to have images? I've been layering with Runefang Steel. It makes it nearly impossible to highlight, but when the light catches the metal it turns a blinding white. That's pretty platinum, right? Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/#findComment-3955809 Share on other sites More sharing options...
Father Mehman Posted February 19, 2015 Share Posted February 19, 2015 I don't happen to have any images but I've used white washes before for force weapons. It gives it a hazy effect. For metal, it'll give it a really good sheen. Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/#findComment-3955904 Share on other sites More sharing options...
MedPig Posted February 19, 2015 Share Posted February 19, 2015 I think Reaper makes a color called "Platinum". Check around. You can always shade it with thinned down Nuln, or Blue, depending where you want it to go. I don't use it much, but if you are using Mithril Silver, and need a lighter highlight color than THAT, use the Platinum. Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/#findComment-3956056 Share on other sites More sharing options...
Razblood Posted February 25, 2015 Share Posted February 25, 2015 P3 Radiant Platinum is your friend ;) Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/#findComment-3961278 Share on other sites More sharing options...
Bryan Blaire Posted February 27, 2015 Share Posted February 27, 2015 Another thing you could possibly do is take some Runefang Steel/Mithril Silver and add a drop or two of white, then mix in some iridescent medium (the more you mix in, the more reflective flakes it will have, but the thinner the color pigments will be). Link to comment https://bolterandchainsword.com/topic/303682-making-platinum/#findComment-3963234 Share on other sites More sharing options...
