Wiffinberg Posted February 23, 2015 Share Posted February 23, 2015 Hey guys & gals, Just asking if anyone else has uses PA thunder hammers on assault terminators before? I had some left over from a vanguard veteran kit and have been kit-bashing some assault terminators together with Deathwing storm shields Are the hands too small for terminators or will it look OK I can post pictures after work for reference but I'm sure most of you know what it looks like Link to comment https://bolterandchainsword.com/topic/303870-pa-thunder-hammers-on-terminators/ Share on other sites More sharing options...
Brother Dallo Posted February 23, 2015 Share Posted February 23, 2015 I'd try to avoid matching up power armour and terminator armour, as the size difference is reasonably pronounced. Yeah, you may not notice it at 3 ft, but personally, I wouldn't do it. However, weapons are fair game though, so swapping the power sword etc. for a PA thunder hammer should look fine, and give a good bit of variety. Hope this helps. Dallo Link to comment https://bolterandchainsword.com/topic/303870-pa-thunder-hammers-on-terminators/#findComment-3959978 Share on other sites More sharing options...
Lucio Posted February 23, 2015 Share Posted February 23, 2015 If you do it, cut the hand at the wrist and attach to a standard Terminator arm to avoid the size difference becoming a problem.You can then assemble the power armour arm with whatever Terminator weapon it replaces and use them to make some squad Sergeants. Link to comment https://bolterandchainsword.com/topic/303870-pa-thunder-hammers-on-terminators/#findComment-3960099 Share on other sites More sharing options...
Wiffinberg Posted February 24, 2015 Author Share Posted February 24, 2015 I mean the other way around, using a standard PA marine hand holding a thunder hammer on a terminator sized arm, I suppose I can cut the hammer off at the hand and fit to terminator hands, will have to dig arround in the bitz box Link to comment https://bolterandchainsword.com/topic/303870-pa-thunder-hammers-on-terminators/#findComment-3960209 Share on other sites More sharing options...
Disruptor_fe404 Posted February 24, 2015 Share Posted February 24, 2015 I mean the other way around, using a standard PA marine hand holding a thunder hammer on a terminator sized arm, I suppose I can cut the hammer off at the hand and fit to terminator hands, will have to dig arround in the bitz box The issue you'll run into is there are very few Terminator (right) hands that aren't gun gripping (I'm assuming you're leaving the storm shields in the left hands). The alternative I'd suggest: if you're using Deathwing storm shields, is it safe to assume that you aren't using the maces? If you aren't, just replace the mace heads with thunder hammer heads. Link to comment https://bolterandchainsword.com/topic/303870-pa-thunder-hammers-on-terminators/#findComment-3960251 Share on other sites More sharing options...
Wiffinberg Posted February 24, 2015 Author Share Posted February 24, 2015 just replace the mace heads with thunder hammer heads. *Facepalm* How did I miss that!? haha thanks brother Link to comment https://bolterandchainsword.com/topic/303870-pa-thunder-hammers-on-terminators/#findComment-3960305 Share on other sites More sharing options...
