Emperor's Furor Posted February 26, 2015 Share Posted February 26, 2015 I was wondering, do you think it would be ok to use boarding shields as combat shields for command squads? I was thinking of taking a breacher squad and the Mk III power weapon set and putting them together to make the other 3/4 members that will go with the mk III commander and standard bearer and eventually Armillus Dynat. Link to comment https://bolterandchainsword.com/topic/303986-command-squad-with-boarding-shields-count-as-combat-shields/ Share on other sites More sharing options...
Grotsmasha Posted February 26, 2015 Share Posted February 26, 2015 As long as *every* boarding shield in your list is a Combat Shield I don't see any reason why any one would have a problem with them being modeled that way. Cheers, Kono Link to comment https://bolterandchainsword.com/topic/303986-command-squad-with-boarding-shields-count-as-combat-shields/#findComment-3962774 Share on other sites More sharing options...
Emperor's Furor Posted February 26, 2015 Author Share Posted February 26, 2015 I'd have breachers so they'd have boarding shields, but if every shield in the command squad was a combat shield would that be ok or am I stretching it.. Link to comment https://bolterandchainsword.com/topic/303986-command-squad-with-boarding-shields-count-as-combat-shields/#findComment-3962786 Share on other sites More sharing options...
tdemayo Posted February 26, 2015 Share Posted February 26, 2015 I certainly would not object, and I doubt anyone else would either, so long as you clearly indicated what counts as what. Link to comment https://bolterandchainsword.com/topic/303986-command-squad-with-boarding-shields-count-as-combat-shields/#findComment-3962866 Share on other sites More sharing options...
infyrana Posted February 26, 2015 Share Posted February 26, 2015 I guess you could attempt to distinguish them by using paint schemes or symbols on the shields - clear ones at that, or modify the shields' shape if you can. Personally I'd have no issue so long as it/they are clearly distinguishable from the standard boarding shields. Link to comment https://bolterandchainsword.com/topic/303986-command-squad-with-boarding-shields-count-as-combat-shields/#findComment-3962899 Share on other sites More sharing options...
